Archived from groups: microsoft.public.windowsme.general (More info?)
"Hi people, I’m new here! Hopefully you can help, here goes:-
My PC is running Windows ME on a PIII 750 with 256 ram & 30gb hard
disk with plenty space free.
Booting this machine is becoming something of a nightmare! I’m
pulling my hair out!!! Its frequently taking numerous attempts to get
a successful bootup. Keep getting blue screens saying "an excetion OE
has occurred at VxD VMM(01) then a couple of strings of numbers (which
I think maybe are locations on the HD) it also says "it may be
possible to continue press any key to continue" then after that
happens usually the same thing will repeatedly occur several times
then the PC will either stabilize or automatically reboot. When this
reboot thing occurs the same thing often follows untill eventually I
get a sucessful boot. It can take 10 attempts to get the PC up and
running! By the way these blue screens seem to occur right at the very
end of the boot up attempt, as all the icons in the sytem tray have
finally appeared.
My knowledge of computers is scarce, thats why I’ve been searching for
help and eventually found here! What I have tried so far is to run a
full scan of my PC with both AVG and Mc Afee anti virus(both fully
upto date) - to no avail - I had initially suspected some sort of boot
virus but it seems not to be the case.
Since then I’ve downloaded a program called Windows Registry Repair,
which has cost me a few £’s and that didn’t sort my problem as I’d
hoped it would. It has made the PC run a lot faster - like it used to
when it was new. That on its first scan of my registry found 511
errors! Which as I said has made a world of difference in the speed of
my PC and crashes are less frequent, but the boot up problem remains.
I’m desperately hoping you guys can help! I don’t want to have to
reformat if at all possible but soon I think if I don’t find some
answers that will be the only choice.
Oh yes also please could you tell me how to clear out some of the
unwanted icons in the system tray? Its getting rather full with 8 or 9
icons in there at start up! I usually end up closing them once the PC
has finally booted up."
Just out of curiosity, did you download the Windows Update KB891711?? Do a
C-A-D and look at your running processes to see if you have KB891711.exe
running. If so, take a look at the prior posts regarding this update. If
this is the case, you may want to disable this item in MSCONFIG and see if
that makes a difference.
Re: items in the Systray........take a look at one or more of these sites
that will tell you what you need at Startup and what is fluff.......
Pacs-Portal and Whidbey are a couple of the best, BTW.
Heirloom, old and going to watch 24
"sir-axeman" <UseLinkToEmail@WindowsForumz.com> wrote in message
news:3_1077558_b48f281f63b1fdbf21f9d1e98d4e635a@windowsforumz.com...
> "Hi people, I'm new here! Hopefully you can help, here goes:-
> Booting this machine is becoming something of a nightmare! I'm
> finally appeared.
> My knowledge of computers is scarce, thats why I've been searching for
> Since then I've downloaded a program called Windows Registry Repair,
> which has cost me a few £'s and that didn't sort my problem as I'd
> I'm desperately hoping you guys can help! I don't want to have to
> reformat if at all possible but soon I think if I don't find some
> Posted using the http://www.windowsforumz.com interface, at author's
request
> Articles individually checked for conformance to usenet standards
> Topic URL:
http://www.windowsforumz.com/Gener [...] 44158.html > Visit Topic URL to contact author (reg. req'd). Report abuse:
http://www.windowsforumz.com/eform.php?p=1077558
Your knowledge of computers may stay scarce if you continue
to do as you did here. In that error message were numbers.
More important than the words were the numbers. Record and
post those numbers. The alternative is a long list of thises
and thats that would take days to sort out. Repost an exact
wording of every error messge - especially with numbers.
In the meantime, fill the screen with more icons. Makes
absolutely no difference to booting. To delete, right click on
the icon, and select from options.
In the meantime, look for diagnostics from your disk drive
manufacturer, memory diagnostics such as Docmem or Memtst86,
video controller manufacturer diagnostics, etc. You may or
may not need these. Better to start downloading and storing
them so that you have them to execute now or for future use.
> finally appeared.
http://www.microsoft.com/athome/se [...] fault.aspx In Memorium: Alex Nichol
http://www.microsoft.com/windowsxp [...] ichol.mspx Your cooperation is very appreciated.
> finally appeared.
request
> Topic URL:
Ahh, I misunderstood. I guess this makes you a "graphic artist".
Jack E. Martinelli 2002-05 MS MVP for Shell/User / DTS
Help us help you: http://www.dts-L.org/goodpost.htm
"Henry" <spam@ftc.gov> wrote in message
news:IHn_d.66584$SF.47081@lakeread08...
> I didn't rename the logo.sys file, I changed the contents of it, and
resaved
> it under the original filename. Windows displays it without any problem.
> Henry
<SNIP>
