Tom's Hardware > Forum > Windows 7 > Windows 7 General Discussion > Does Win 7 fix the 4GB RAM problem in Vista?
System Specs:
Intel Core2Duo E8500
4GB (2x2GB) DDR2 HyperX RAM
Nvidia Geforce 8800 Alpha Dog edition 512MB 650 MHz
P5N7A-VM Mobo (nVidia 9300 iGPU)
Windows Vista Home Premium 32
I've got the annoying problem of Vista only recognising something like 3.2-3.5GB or RAM instead of the full 4GB. If I switch to 64-bit Win 7, will this problem dissappear, or will it still allocate video memory out of my RAM?
I'm still very confused about how the iGPU works in HybridSLI, like where its memory and processing power comes from. If I change the iGPU frame buffer size in the BIOS, does Vista allocate, say 512MB, out of my RAM to the iGPU, or how does it work?
thanks for the help guys
Sponsored Links
If you switch to W7 or Vista 64 bit, it will recognize 4GB+ of ram. 32 bit will only recognize up to 3.5GB.
------------------------------ -Kevin
Desktop: Q9400(stock,lapped,SpinTechQ)/Intel DP43TF/Sapphire 4850(2GB)x2/8GB DDR2 800Mhz/X-Fi Titanium Pro/Liteon BD-ROM/Velociraptor/Windows 7 Pro 64-bit
Laptop: Little Toshiba Satellite (M305)/T6400/4GB DDR2 800Mhz/Windows 7 RC 64-bit (for now
Reply to buwish
- 0 +
Yeah, the 4GB "problem" isn't a "Vista" issue, it's a 32-bit issue. A 64-bit OS (XP, Vista or Windows 7) will be able to access more than 4GB of memory.
Reply to sminlal
- 0 +
you can have up to 16 GB of memory in Windows Vista/7 x64
i believe its even higher (128?) in Windows Ultimate
Reply to arges86
- 0 +
Home Premium - 16GB
Pro / Ultimate / Enterprise - 192GB
------------------------------ Desktop: Windows 7 Professional 64-bit; Intel Q6600 CPU; E-VGA 780i SLI motherboard; E-VGA E-GeForce 8800GT; OCZ Vista 4GB dual-channel kit; Ultra X2 750W power supply; 2 x Seagate Barracuda 7200.11 500GB in RAID 0. Laptop: Acer Aspire 8730-6314;
Reply to Zoron
- 0 +
so i was close
Reply to arges86
nearly all wrong, you can actualy use upto 64GB ram in Vista by copying the memory managment part from an activated install of Win2k8 server, as described here
presumably all other Win versions can also use upto 64GB
Reply to donkey42
- 0 +
I'm referring to what MS officially supports... not unsupported hacks. Besides, why waste your time with 32-bit workarounds when 64-bit is quickly becoming the standard? Secondly, no home user is going to be able to make use of more than 16GB of RAM anyway. Thirdly, finding drivers that are "large address aware" is extremely difficult.
Reply to Zoron
well i could say i disagree but i'd be wrong because i actually agree, so well said
BTW: i'm currently using a 32 bit vista so hacks official or unofficial are usefull to me and probably many other users
Reply to donkey42
- 0 +
hacking a 32-bit system to run w/ more RAM is kinda inefficient doe to inherited limitations of the technology
Reply to arges86
inefficiet, how ? - 64GB is very much overkill but it's better than 3GB ish by default, and as Zoren said
Quote :
Reply to donkey42
- 0 +
By the time the next MS OS rolls out, I'm predicting that 64-bit will be the standard with a few 32-bit holdouts. If MS decides that it's next OS will be 64-bit only, then that pretty much signals the end of the 32-bit OS. After all, 64-bit Windows is still fully capable of running 32-bit programs... so continuing to offer both won't make a lot of sense... especially when more 64-bit apps start hitting the market.
Reply to Zoron
- 0 +
the only issue w/ x64 are some legacy devices and software that are 16-bit that won't run on a x64 machine...
i personally don't think i've run software/ used hardware that old in a long time
Reply to arges86
There are 830 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 paesan won the Freshman badge
  • 01:00 -pcaddict- won the Freshman badge
  • 01:00 impreza won the Freshman badge
  • 01:00 raulkm won the Uniformed badge
  • 01:00 letus won the Uniformed badge
  • 01:00 pmiddy won the Uniformed badge
  • 01:00 MarcieMark won the Uniformed badge
  • 01:00 kaypeezee won the Uniformed badge
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
