speakers dont work help
Archived from groups: microsoft.public.windowsme.general (More info?)
hi every one im running a windows me i have a flat scree with built in
speakers i tried them the other day (all pluged in) they didnt work i tried
another pair of working speakers they dont work what should i do
jake
1 answer Last reply
More about speakers dont work help
  1. Archived from groups: microsoft.public.windowsme.general (More info?)
    In news:1B124999-768E-46C2-A738-952BF9CA5187@microsoft.com,
    jakethegunner <jakethegunner@discussions.microsoft.com> had this to say:
    My reply is at the bottom of your sent message:
    > tried another pair of working speakers they dont work what should i do
    > jake
    Make sure they're plugged into the right spot on the sound card. Make sure
    that the sound isn't muted. Open the volume control from the control panel.
    Turn up the sound all the way and make sure that the box to mute them isn't
    ticked. Then, start by turning on a music file, any one will do, and just
    set it to repeat/replay. Climb behind your box and plug the cords into any
    slot that fits. Usually it will be easy to tell which one it goes into but,
    just in case, keep trying that until all possibilities have been explored if
    they're not labeled clearly.
    Galen
    Signature changed for a moment of silence.
    Rest well Alex and we'll see you on the other side.
Windows Me Speakers Microsoft Windows
