Tom's Hardware > Forum > Windows 95/98/ME > Windows 95/98/Me General Discussion > system errors(blue screen) problems
Archived from groups: microsoft.public.windowsme.general (More info?)
starting getting blue screen problems from different actions but all have the
same error code 06:0000:00000813 but cannot find this code listed any
where.Virus checks and adware programs run but nothing comes up.If any one
has any ideas or can tell me a good place to find a complete list of system
error codes I'd be gratefull.
Thx
pplxd
Sponsored Links
The problems you are seeing appear to be being caused by the 891711 hotfix
with some users having major problems such as you are seeing and others,
myself included, having none. The cause of the problems and BSODs seem to
be related to the video chip and version of the driver on the box rather
than the browser or other software installed.
If you have installed the 891711 hotfix I would suggest that you consider
either uninstalling 891711 using Add/Remove Programs where it appears as
"Windows Millennium Edition KB891711 Update" or perhaps better to prevent
the KB891711 service being launched each time you boot your PC uncheck the
KB891711 entry in MSConfig | Startup (Accessed using Start | Run and
entering MSConfig in the box and clicking OK). Alternatively you could
use system restore to roll your system back to the state it was in before
you installed the 891711 hotfix.
Out of curiosity what video card do you have installed in the affected box
and what version driver is it using?
http://www.microsoft.com/windowsxp [...] ichol.mspx
In memory of a very dear friend, Windows MVP Alex Nichol
Mike Maltby MS-MVP
mike.maltby@gmail.com
> have the same error code 06:0000:00000813 but cannot find this code
> listed any where.Virus checks and adware programs run but nothing
> comes up.If any one has any ideas or can tell me a good place to find
> a complete list of system error codes I'd be gratefull.
Reply to Anonymous
There are 1214 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
