G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Hi,
I'm a bit paranoid. I have a 350W power supply, used to power a P4 2.4GHz
on 865PE based mobo, a DVDROM, a CDRW, 2 HDD and a 3.5" FDD. The power
supply have 5 sets of output cables in this cofiguration:
1 set for ATX power (20 pin header)
1 set for ATX +12V (4 pin header)
1 set for legacy mobo power (remnants from AT days)
2 set for general peripheral (i.e. HDD power)
The general peripheral set have the following headers and current usage:
1 set have 2 output headers (used for both HDD)
1 set have 2 output headers plus one for FDD power (used DVDROM, CDRW and
FDD)
I recently added a casing fan, with power header matching the general
purpose headers. I suppose I have to use splitter cables (Y-Cables) on
one of the headers which belongs to one of the aforementioned sets. So,
to which set do I connect it to (the set for both HDD or the one for
DVD/CDRW/FDD) to ensure power stability (prolong the lifetime of the
attached peripherals, in terms of power)?
PS: The mobo supports 1 additional system fan with 3 pin power header.
Strangely, I couldn't find any local dealers who carries such fans with
matching power input headers. They only carry those with general purpose
input headers. I have difficulties with buying online, not to mention the
shipment fees will outweigh the fan's price.
TIA
Hi,
FDD)
TIA
