Archived from groups: microsoft.public.windowsme.general (More info?)
I am not able to access the Help section of Microsoft Money 2003. I receive
the error "Unable to load topic. Click here to try again." And, of course,
clicking again does nothing...
Here's what I have tried do far:
reinstall/repair of Money 2003
deleted temporary internet files, cookies and cleared history.
I read Microsoft Article ID : 312808. I tried installing the HTML Help
update. It didn't help.
I have also read and performed steps in Microsoft Article ID : 812755 - no
help there, either.
I already posted to Microsoft.public.money newsgroup, but regrettably I have
not been able to solve this problem.
I am running Windows ME 4.90.3000, and I have the current IE6 SP1 (recently
installed after IERadicator).
If you have any suggestions, please let me know. Thank you.
If you used IEradicator did you follow the rest of the steps in Noel
Paton's page (http://www.btinternet.com/~winnoel/ReInIE.htm) or not? I
mentioned this in a previous post but don't recall having seen your reply.
Until you fix the many problems caused by using IEradicator I'm not
surprised to read you're having problems.
Mike Maltby MS-MVP
mike.maltby@gmail.com
> receive the error "Unable to load topic. Click here to try again."
> And, of course, clicking again does nothing...
> - no help there, either.
> I have not been able to solve this problem.
> (recently installed after IERadicator).
Yes, I completed the rest of those steps, and Internet Explorer works fine
now.
Microsoft Money 2003 works, too, with the only exception being I am not able
to access the Help section. I continue to receive the error "Unable to load
topic. Click here to try again." As I mentioned, clicking again does
nothing....
"Mike M" <No_Spam@Corned_Beef.Only> wrote in message
news:eUFrU2AMFHA.4028@tk2msftngp13.phx.gbl...
> Mike Maltby MS-MVP
"Home User" <Home_User@no.spam.net> wrote in message
news:1144e2u4qopjgf4@corp.supernews.com...
> now.
> able
> load
> nothing....
>> reply.
>> Mike Maltby MS-MVP
Yes. Help and Support from the Start Menu works fine.
"Noel Paton" <NoelDPspamless@btopenworld.com> wrote in message
news:uu4RrlDMFHA.3296@TK2MSFTNGP15.phx.gbl...
> Does Help and Support work OK from the Start Menu?
> Noel Paton (MS-MVP 2002-2005, Windows)
> Nil Carborundum Illegitemi
> http://www.btinternet.com/~winnoel/millsrpch.htm >
> In fond memory of one of life's Gentlemen - Alex Nichol
> http://www.aumha.org/alex.htm >
> Please read http://dts-l.org/goodpost.htm on how to post messages to NG's
fine
> > now.
> > able
> > load
> > nothing....
> >> reply.
> >> Mike Maltby MS-MVP
Help
Perhaps only the Help file for Money is corrupted. Find it in the Money
folder and try to start it. If it fails, see if it can be refreshed from
the Money installation CD without reinstalling Money.
Jack E. Martinelli 2002-05 MS MVP for Shell/User / DTS
Help us help you: http://www.dts-L.org/goodpost.htm
http://www.microsoft.com/athome/se [...] fault.aspx In Memorium: Alex Nichol
http://www.microsoft.com/windowsxp [...] ichol.mspx Your cooperation is very appreciated.
> now.
able
load
> nothing....
reply.
> > Mike Maltby MS-MVP
I found the help file in the Money folder and tried to start it:
"msmoney.chm". It failed. All I got is a blank "? help pane". I then
deleted it in case it was corrupt.
I extracted the original to my computer, off my original Money CD. However,
It doesn't work either! When I start it, all I get is the blank page.
So... I manually checked all of my other help files (*.chm files), and they
all work fine. The ONLY exception is msmoney.chm.
I tried to start it directly from the installation CD, no luck there,
either!
I'm stumped! Please help, if you have any more suggestions.
Thank you.
It doesn't work when I open it. It brings up a blank screen with the
"Jack E Martinelli" <jemartin_DELETE@NO_SPAM_gis.net> wrote in message
news:eyKchEHMFHA.1392@TK2MSFTNGP10.phx.gbl...
> Help us help you: http://www.dts-L.org/goodpost.htm >
> http://www.microsoft.com/athome/se [...] fault.aspx > In Memorium: Alex Nichol
> http://www.microsoft.com/windowsxp [...] ichol.mspx > Your cooperation is very appreciated.
fine
> > now.
> able
> load
> > nothing....
I
> reply.
> > > Mike Maltby MS-MVP
Help
812755
regrettably
news:11463133lf27cfd@corp.supernews.com...
However,
they
> either!
> Thank you.
from
> > Help us help you: http://www.dts-L.org/goodpost.htm > >
> > http://www.microsoft.com/athome/se [...] fault.aspx > > In Memorium: Alex Nichol
> > http://www.microsoft.com/windowsxp [...] ichol.mspx > > Your cooperation is very appreciated.
> fine
> > > now.
not
> > able
to
> > load
> > > nothing....
> I
> > reply.
> > > > Mike Maltby MS-MVP
I
> Help
> 812755
> regrettably
HU, what is the size of the (downloaded) msmoney.chm file and are you able
to see any contents using a text viewer e.g. notepad, etc?
I don't have a copy of Money 2003 so I can't compare it for you, but from
what you are reporting, it 'appears' to be an empty file.
I think Jacks advice is probably best.
Mart
news:uPRI8IVMFHA.3340@TK2MSFTNGP14.phx.gbl...
>I am as stumped as you, and recommend speaking to MS Money support, since
> only their Help file is failing to show.
> However,
> they
>> either!
>> Thank you.
>> > Money
> from
>> > Help us help you: http://www.dts-L.org/goodpost.htm >> >
>> > http://www.microsoft.com/athome/se [...] fault.aspx >> > In Memorium: Alex Nichol
>> > http://www.microsoft.com/windowsxp [...] ichol.mspx >> > Your cooperation is very appreciated.
>> fine
>> > > now.
> not
>> > able
> to
>> > load
>> > > nothing....
>> > > > Noel
>> > > > not?
>> I
>> > reply.
>> > > > Mike Maltby MS-MVP
> I
>> > > > > again."
>> Help
>> 812755
>> regrettably
I broke down and called Microsoft Support. I spoke with a tech on the phone
for a while. We covered a lot of things, and we tried a few fixes. But, at
this juncture, the problem is still unresolved. They are looking into it. I
hope to hear back from them in a day or two.
"Mart" <mart(NoSpam)@nospam.com> wrote in message
news:eOjsyQWMFHA.2132@TK2MSFTNGP14.phx.gbl...
> Mart
> > However,
> > they
> >> either!
> >> Thank you.
> >> > Money
> > from
> >> > Help us help you: http://www.dts-L.org/goodpost.htm > >> >
> >> > http://www.microsoft.com/athome/se [...] fault.aspx > >> > In Memorium: Alex Nichol
> >> > http://www.microsoft.com/windowsxp [...] ichol.mspx > >> > Your cooperation is very appreciated.
works
> >> fine
> >> > > now.
> > not
> >> > able
"Unable
> > to
> >> > load
does
> >> > > nothing....
> >> > > > Noel
> >> > > > not?
> >> I
your
> >> > reply.
not
> >> > > > Mike Maltby MS-MVP
2003.
> > I
> >> > > > > again."
HTML
> >> Help
> >> 812755
> >> regrettably
SP1
