Monitor switches off
Forum Homebuilt Systems : General Homebuilt - Monitor switches off
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Hi,
A PC I have been given has a annoying habit of turning off the monitor after
being switched on after a few seconds.
The longest it's been running is the Win98se splash screen is shown!
The CD draws also stops working, but both fans remain on, there is no disk
activity after the monitor turns off.
I can't press F8 or enter BIOS with no monitor, or can I.
Will.
[Also posted in alt.windows98]
Sponsored Links
"Will" <will@hotmail.com> wrote in message
news:crhmvn$l9l$1@sparta.btinternet.com...
> Hi,
> after
> Will.
I haven't seen that particular symptom, but I suspect it is a bad power
supply. It almost always is. -Dave
Reply to Anonymous
On Wed, 5 Jan 2005 21:42:15 +0000 (UTC), "Will" <will@hotmail.com> wrote:
>Hi,
>Will.
If you boot from a floppy disk it does the same thing?
Bad powersupply or CPU overheating? I'd check out those.
Michael Cecil
http://home.comcast.net/~macecil/
Reply to Anonymous
It won't boot from a floppy. Not on long enough to overheat (a matter of
seconds).
Will.
"Michael Cecil" <macecil@comcast.net> wrote in message
news:8esot01b0i8idn5ivm29bnnohnm7s68e92@4ax.com...
> >Hi,
after
disk
> >Will.
> Michael Cecil
Reply to Anonymous
Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Monitor switches off
There are 1228 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
