G
Guest
Guest
Archived from groups: microsoft.public.windowsme.general (More info?)
I have two errors that keep popping up:
1st: Error Loading C:\progra~1\wildta~1\apps\cda\cdaeng~1.dll The System
cannot find the path specified.
2nd: The shortcut 'Slide Show.ink' refers to a location that is unavailable.
The location could be on a harddrive on this computer,....Check to make sure
that the disk is properly inserted or that you are connected to the internet
or home network, and then try again.
2nd message appeared after I tried to uninstall DSL software (SBC). The
first one has been around for a while and can't get rid of it. I've been
using the computer by clicking ok on it and just going on. Now, my computer
has started to freeze up quite a lot. Please help, and if you can give me a
novice's version of your explanation, I'd be thankful.
TheDacian - ready to throw the computer out the window
