G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
I have just built a new pc,with a case with firewire port on front
panel, i have a firewire card but the port on the front has six wires
coming of it, to be plugged into the M/B. My M/b has not got the
connections. My question is.....Can i make up a lead that i can plug
into the firewire card at rhe rear, then bring the cable through the
case to the front panel, by cutting a firewire lead then joining it to
the six wirres? I have a diagram of firewire cabling, but am not sure
if all leads are the same. Any help on this would be greatfully
received.
received.
