Help with Slave/Master Settings
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Building a new PC with son.
Installed components last night and have a question about the
slave/master settings on the hard drive and the CD/DVD drive. There
is no floppy at the present.
I have the HD set to master and the CD/DVD set to slave, but the
illustration that came with the CD drive indicates that I should set
that to master.
Any thoughts?
TIA,
Douglas
13 answers Last reply
More about help slave master settings
  1. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    In article <eiicv01igfi84mscchm47srbe5ueio1q27@4ax.com>,
    >that to master.
    >Any thoughts?
    >TIA,
    >Douglas
    Setup on a PC with one disk and one CDR is generally that the disk
    is on the primary IDE channel and the CDR is on the secondary
    channel and neither needs master/slave jumpers.
    The few times I've shared an IDE channel on a modern mobo the
    controller recognized the two devices and did the right thing, with no
    jumpers in either device.
    a d y k e s @ p a n i x . c o m
    Don't blame me. I voted for Gore.
  2. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    you have TWO ide channels so put the hard drive on the PRIMARY ide channel
    and the dvd on the SECONDARY ide channel
    Set both devices to MASTER
    "Douglas Fifield" <douglas.fifield@comcast.net> wrote in message
    news:eiicv01igfi84mscchm47srbe5ueio1q27@4ax.com...
    > that to master.
    > Any thoughts?
    > TIA,
    > Douglas
  3. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    On Tue, 25 Jan 2005 14:35:50 +0000 (UTC), "Ginchy"
    >> that to master.
    >> Any thoughts?
    >> TIA,
    >> Douglas
    I have changed the setup as you suggested. Will let you know how it
    works.
    D.
  4. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    you must have used cable select
    "Al Dykes" <adykes@panix.com> wrote in message
    news:ct5jp5$gjd$1@panix5.panix.com...
    > >that to master.
    > >Any thoughts?
    > >TIA,
    > >Douglas
  5. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Now how would you setup the following configuration?
    2 hard drives
    1 DVD burner
    1 CD burner
    My main consideration here would be not to slow down the transer
    speeds of the HD's with the slower DVD and or CD.
    Thanks for the help.
  6. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    >2 hard drives
    >1 DVD burner
    >1 CD burner
    Buy an add-on IDE card for a few bucks and give each of your
    devices it's won channel.
  7. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    <James> wrote in message news:9mngv0lfbtkuu8u2ju4k8scmmmn4vgrret@4ax.com...
    > 2 hard drives
    > 1 DVD burner
    > 1 CD burner
    Put them wherever you want.
    http://www.pcguide.com/ref/hdd/if/ide/confTiming-c.html Doesn't matter
    anymore.
    If you want to copy on the fly, seperate the cd drives. But with
    "burn-proof" et al, even that doesn't matter anymore.
  8. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    >anymore.
    I should have mentioned that the second HD is kept in a removable
    drawer and is not always present in the system.
    Right now the CD burner is on the secondary master. When I insert the
    second HD it of course becomes the primary sleeve. As such that HD
    drops down to ATA 33 instead of ATA 100?
  9. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    You know adykes I think you have hit on the perfect solution. :-))
    Thanks for the reply.
  10. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    <James> wrote in message news:07biv05sko1jsob9r95jurt3ni7b1q296q@4ax.com...
    >>anymore.
    For the second time, no it doesn't.
  11. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    On Thu, 27 Jan 2005 20:59:47 GMT Not alowing their prejudice to rule
    >>>anymore.
    We'll keep telling em Bill.These Myths will continue but we are here
    to put them straight :P
    Free Windows/PC help,
    http://www.geocities.com/sheppola/trouble.html
    remove obvious to reply
    email shep@obviouspartyheld.de
    Free original songs to download and,"BURN" :O)
    http://www.soundclick.com/bands/8/nomessiahsmusic.htm
  12. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Ok it does not go down to ATA 33 if that makes you happier. I am
    making it all up.
    But the problem was solved very easily. I have a Gigabyte 7DXR mobo.
    Which has two RAID controllers. End of problem.
  13. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    > wrote:
    >  >>Put them wherever you want.
    >  >>http://www.pcguide.com/ref/hdd/if/ide/confTiming-c.html
    > Doesn't matter
    >  >>anymore.
    >  >>If you want to copy on the fly, seperate the cd
    > drives. But with
    >  >>"burn-proof" et al, even that doesn't matter anymore.
    > removable
    > insert the
    > that HD
    I am building a new system with 1 HDD, 1FDD, 1 CD ROM and 1 DVD RW.
    There are 2 IDE connectors, and one for the FDD, what config should
    they be in?
    Thanks
    Posted using the http://www.hardwareforumz.com interface, at author's request
    Articles individually checked for conformance to usenet standards
    Topic URL: http://www.hardwareforumz.com/Home-Built-Help-Slave-Master-Settings-ftopict46864.html
    Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.hardwareforumz.com/eform.php?p=234290
Homebuilt CD-Rom Systems
