Yes No
Ads
Tom's Hardware > Forum > Windows XP > General Discussion > Help stop code nightmare
Forum Windows XP : General Discussion Help stop code nightmare
Archived from groups: microsoft.public.windowsxp.basics (More info?)
Can anyone please help me on this problem. I have removed all the cards and still wont boot. I have run a check disk no results. Please someone help.
TIA
Thanks but waht about the other codes? What are they pointing to? Where could I find this info at?
"Frank GoBell" wrote:
> Ron <Ron@discussions.microsoft.com> wrote:
> > I just installed XP on a new hard drive and keep getting the
> > following stop code 0X0000007B, (0XFC8D3640, 0XC0000034, 0X00000000,
> > 0X00000000). Any help on this to get past this error code would be
> > much appreaciated.
> > Thanks.
> http://support.microsoft.com/default.aspx?scid=kb;[LN];324103
> --Â?
> Frank GoBell
Reply to Ron
Pulling cards won't help in this instance:
http://support.microsoft.com/defau [...] duct=winxp
-or possibly-
Walter Clayton - MS MVP(WinXP)
Associate Expert
http://www.microsoft.com/windowsxp/expertzone
Any technology distinguishable from magic is insufficiently advanced.
http://www.dts-l.org
http://support.microsoft.com/servi [...] fault.asp|
"Ron" <Ron@discussions.microsoft.com> wrote in message
news:900A5A14-D6BB-412E-A896-586E7F1E86E4@microsoft.com...
> help.
> TIA
>> > much appreaciated.
>> > Thanks.
>> --Â?
>> Frank GoBell
Reply to Anonymous
Chkdisk isn't enough, use the hard drive's diagnostic tools, it should have
come with a disk, if not, check the manufacturer's website for their
diagnostic tools and run them on the drive.
If it appears ok, the problem most likely is the drive is not properly
connected or jumpered assuming XP was on the previous drive and you had no
issues such as this.
Note: if XP was supplied with your PC, it's possible that's the problem as
your version was likely tied to the original hardware and sometimes cannot
be changed. If XP was supplied with your system, you might need to contact
the system builder for help resolving this issue.
Michael Solomon MS-MVP
Windows Shell/User
Backup is a PC User's Best Friend
DTS-L.Org: http://www.dts-l.org/
> help.
> TIA
>> > much appreaciated.
>> > Thanks.
>> Frank GoBell
Reply to Anonymous
There are 1995 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Microsoft Updates - In Triplicate !
By Hawkeye22, 2 days ago:
They won't show up in add/remove programs because they were superceded by a different...
Best offers
Top experts
