Archived from groups: microsoft.public.windowsme.general (More info?)
I have a problem removing a couple of Trojans from my system when I use Avast
AV in a thorough scan. It tells me that files in
C:\_restore\archive\FS44.cab\A003894.cpy and ...\FS47.cab\A004125.cpy have
trojans but can't fix, remove, quarantine them.
Can I remove these files manually and reinstall clean versions? If not, what
else should I do to delete the Trojans?
>Avast
> what
> James
Delete your restore points as it seems they are hanging out in there. If
that doesn´t work, boot up to DOS and delete them there.
These infections cannot harm you where they are - they are in the System
Restore archive.
The only way they can harm your system is if you restore the system to a
time during which it was infected - and eventually the infected restore
points will be removed by FIFO.
If you're concerned that you may inadvertently use an infected restore
point, reset System Restore to clear all old points, and create a new on -
do NOT attempt manual editing of the archive!!
To Reset System Restore -
System | Performance | File System | Troubleshooting and check
"Disable System Restore",
Apply and IMMEDIATELY reboot.
This will flush you restore folder and erase all checkpoints, then,
System | Performance | File System | Troubleshooting and uncheck
Apply and again IMMEDIATELY reboot.
This should now automatically create a new checkpoint immediately following
the restart.
Finally adjust the space allocated to the restore folder,
System | Performance | File System | Hard Disk and adjust the restore slider
to your preferred setting.
Most people find that a setting of 200-300MB is sufficient to hold 10-15
days worth of restore points, unless you are doing a lot of
installs/uninstalls, or installing large applications (such as Office).
"J. Ascher" <JAscher@discussions.microsoft.com> wrote in message
news:8584BE9E-217A-40A6-A764-54F876B94727@microsoft.com...
>Avast
> what
> James
Noel is correct.
Also you might want to run an online scan (it's
independent of your system) to see if anything else is
lurking. It's safe, free and offers peace of mind as not
all AV programs find the same nasties.
Follow these instructions:
Go to this link http://www.ravantivirus.com/ . In the
upper left portion of
the screen, under MENU, you will see "Scan online". Click
on it.
On the next page in the RAV Outbreak Security Service
(orange text) box, at the bottom,
there's line "To continue without subscribing click here.
Click there, no need to
enter anything in the yellow field and no need to hit the
continue button.
On the next page you will be in the scanner. It should
update the latest virus definitions
automatically. Be patient, it will take some time (~15
min. on my slow connection) to update.
After the update is complete (It will say "Update
finished. Ready to scan." when it's done),
check the Autoclean box (right below the Scan My PC
button).
Then press the "Scan My PC" button and you're off. Again,
be patient, this will take some time,
30 minutes on my slow machine.
HTH
KB
>-----Original Message-----
are in the System
>Restore archive.
the system to a
infected restore
infected restore
create a new on -
check
checkpoints, then,
uncheck
>the restart.
the restore slider
of
(such as Office).
>Noel Paton (MS-MVP 2002-2005, Windows)
>Nil Carborundum Illegitemi
>http://www.btinternet.com/~winnoel/millsrpch.htm
>http://tinyurl.com/6oztj
>Please read http://dts-l.org/goodpost.htm on how to post
messages to NG's
message
system when I use
>>Avast
versions? If not,
>> what
>> James
Your information is very good. I tried to download a trial version of RAV AV,
but it told me due to MS' acquition of its intellectual property rights, the
download section is closed. RAV is scaling down and eliminating its AV
business.
James
"KB" wrote:
> Noel is correct.
> on it.
> continue button.
> button).
> HTH
> KB
> are in the System
> >Restore archive.
> the system to a
> infected restore
> infected restore
> create a new on -
> check
> checkpoints, then,
> uncheck
> >the restart.
> the restore slider
> of
> (such as Office).
> messages to NG's
> message
> system when I use
> >>Avast
> versions? If not,
> >> what
> >> James
But you don't need the trial version to do an online
scan. It is run without installing anything on your
system. That's what makes it great. If your system is
compromised or your AV is crippled you can scan without
using your system. Anytime my personal AV finds anything,
it's off to RAV for me.
I suspect you went to RAV and poked around a bit and
didn't find what I was pointing you to. I've heard
similar responses from other users, which is why I created
the instructions in such generic 'easy to follow' detail.
Try printing my instructions and follow them to the letter
and I think you'll be in good shape .
Please let me know if it works out for you.
KB
eliminating its AV
>business.
>James
>"KB" wrote:
>> Noel is correct.
not
Click
>> on it.
here.
the
>> continue button.
>> button).
Again,
>> HTH
>> KB
>> are in the System
>> >Restore archive.
restore
>> the system to a
>> infected restore
>> infected restore
and
>> create a new on -
and
>> check
>> checkpoints, then,
and
>> uncheck
>> >the restart.
folder,
adjust
>> the restore slider
lot
>> of
>> (such as Office).
post
>> messages to NG's
in
>> message
>> system when I use
>> >>Avast
clean
>> versions? If not,
>> >> what
>> >> James
Thanks, I did find the online scan. However, I wanted to see if there were a
trial version of the software.
James
> KB
> eliminating its AV
> >business.
> >James
> >"KB" wrote:
> >> Noel is correct.
> not
> Click
> >> on it.
> here.
> the
> >> continue button.
> >> button).
> Again,
> >> HTH
> >> KB
> >> are in the System
> >> >Restore archive.
> restore
> >> the system to a
> >> infected restore
> >> infected restore
> and
> >> create a new on -
> and
> >> check
> >> checkpoints, then,
> and
> >> uncheck
> >> >the restart.
> folder,
> adjust
> >> the restore slider
> lot
> >> of
> >> (such as Office).
> post
> >> messages to NG's
> in
> >> message
> >> system when I use
> >> >>Avast
> clean
> >> versions? If not,
> >> >> what
> >> >> James
It's good you found the RAV online scan. It's a good
thing to have as a backup, just in case .
If you're looking for a different AV, you might consider
to download, install, and update a trial version of
Kapersky Antivirus.
http://www.kasperskyusa.com/promotions/?Home Kapersky Antivirus Personal 5.0. I haven't used Kapersky
myself but have read in many threads that it's very good,
but costs a little more.
Before installing, get offline and disable your current AV
protection completely. Don't run two AV programs in the
background at the same time as they will have conflicts
with each other. You can have two on your system, just
not running at the same time.
Happy surfing.
KB
see if there were a
>James
anything,
created
detail.
letter
>> KB
intellectual
>> eliminating its AV
>> >business.
>> >James
>> >"KB" wrote:
>> >> Noel is correct.
is
as
>> not
the
>> Click
>> >> on it.
Service
>> here.
hit
>> the
>> >> continue button.
should
(~15
>> >> button).
>> Again,
>> >> HTH
>> >> KB
they
>> >> are in the System
>> >> >Restore archive.
>> restore
>> >> the system to a
the
>> >> infected restore
an
>> >> infected restore
points,
>> and
>> >> create a new on -
Troubleshooting
>> and
>> >> check
>> >> checkpoints, then,
Troubleshooting
>> and
>> >> uncheck
checkpoint
>> >> >the restart.
>> folder,
>> adjust
>> >> the restore slider
a
>> lot
>> >> of
applications
>> >> (such as Office).
>> post
>> >> messages to NG's
wrote
>> in
>> >> message
my
>> >> system when I use
>> >> >>Avast
>> clean
>> >> versions? If not,
>> >> >> what
>> >> >> James
Jack E. Martinelli 2002-05 MS MVP for Shell/User / DTS
Help us help you: http://www.dts-L.org/goodpost.htm In Memorium: Alex Nichol
http://www.microsoft.com/windowsxp [...] ichol.mspx Your cooperation is very appreciated.
"KB" <KB@discussions.microsoft.com> wrote in message
news:0a4201c553de$53b76460$a501280a@phx.gbl...
> Kapersky Antivirus.
> http://www.kasperskyusa.com/promotions/?Home > Kapersky Antivirus Personal 5.0. I haven't used Kapersky
> Instructions on how to run it can be found down a little
> ways in a post here http://castlecops.com/postt106277.html. >
> Happy surfing.
> KB
> see if there were a
> >James
> anything,
> created
> detail.
> letter
> >> KB
> intellectual
> >> eliminating its AV
> >> >business.
> >> >James
> >> >"KB" wrote:
> >> >> Noel is correct.
> is
> as
> >> not
> the
> >> Click
> >> >> on it.
> Service
> >> here.
> hit
> >> the
> >> >> continue button.
> should
> (~15
> >> >> button).
> >> Again,
> >> >> HTH
> >> >> KB
> they
> >> >> are in the System
> >> >> >Restore archive.
> >> restore
> >> >> the system to a
> the
> >> >> infected restore
> an
> >> >> infected restore
> points,
> >> and
> >> >> create a new on -
> Troubleshooting
> >> and
> >> >> check
> >> >> checkpoints, then,
> Troubleshooting
> >> and
> >> >> uncheck
> checkpoint
> >> >> >the restart.
> >> folder,
> >> adjust
> >> >> the restore slider
> a
> >> lot
> >> >> of
> applications
> >> >> (such as Office).
> >> post
> >> >> messages to NG's
> wrote
> >> in
> >> >> message
> my
> >> >> system when I use
> >> >> >>Avast
> >> clean
> >> >> versions? If not,
> >> >> >> what
> >> >> >> James
