Yes No
Ads
hard drive problems
Forum Windows 95/98/ME : General Discussion hard drive problems
Archived from groups: microsoft.public.windowsme.general (More info?)
I have run into a series of hard drive problems that I have tried to
fix. I could not run scandisk through start up of my system. I came to
the conclusion that my best tactic was to buy a new hard drive and
install a clean install of windows me. I connect the old drive that I am
having troubles as a slave and booted on the new drive. I ran scan disk
and this seemed to clean up the problems. I booted on the old hard
drive. I then tried to upgrade my copy of Norton anti virus in order
make sure my problems were not caused by a virus. This did not work . I
could not install the upgrade. I decided that I better boot the new hard
drive with the old drive as a slave again. I installed the new version
of Norton anit virus and ran a scan of both my drives. I lot of spy ware
came up and I deleted all that i could. I then reboot trying to use the
old drive and could not. I get a windows protection fault. I can not
boot in safe mode either. I would guess that I have problems with the
registry. How can I fix this? I can still boot using the new drive with
the old drive as a slave. How can I run a diagnoistic and repair on the
registry of a slave drive? If this can't be done perhaps I should look
at building up a new registry on the new drive.. I do not want to
reinstall all my software as this is very inpractical. What is the
procedure in copying programs over one at a time so that all components
and keys are installed? I can not boot using a floppy as I don't have a
floppy drive. Is there any repair feature on the WindowsME install disk?
Thanks for any help!
Mark
Reply to Anonymous
It's so tempting to turn around and say 'Ditch Norton completely and then we
can start rescuing your Windows installation' - that I think I'll leave it
there.....
Noel Paton (MS-MVP 2002-2005, Windows)
Nil Carborundum Illegitemi
http://www.btinternet.com/~winnoel/millsrpch.htm
http://tinyurl.com/6oztj
Please read http://dts-l.org/goodpost.htm on how to post messages to NG's
"Mark Garron" <caia@xigo.com> wrote in message
news:427FAD59.748CE016@xigo.com...
> Mark
Reply to Anonymous
Thats all well and good to say but...
Norton is completely uninstalled on the old drive. I have two options copy
everything to the new drive. The question becomes how do I copy all keys etc so
that I don't have to reinstall everything. or How do I recover and fix my
registry on the old drive.
Mark
> there.....
> > Mark
Reply to Anonymous
IIUYC, it appears that your NAV scanning of the drives removed an infected,
but critical, WinME OS file resulting in the Windows Protection Error.
IMO, your only simple solution is to attempt a Safe Mode, or DOS mode,
System Restore reversion to a time prior to this infection. If this fails,
a backup restoration or a clean install are the feasible options.
Jack E. Martinelli 2002-05 MS MVP for Shell/User / DTS
Help us help you: http://www.dts-L.org/goodpost.htm
In Memorium: Alex Nichol
http://www.microsoft.com/windowsxp [...] ichol.mspx
Your cooperation is very appreciated.
news:427FB0DF.1AF7F288@xigo.com...
etc so
> Mark
then we
it
> > there.....
NG's
am
disk
I
hard
ware
the
with
the
components
a
disk?
> > > Mark
Reply to Anonymous
safe mode system restore is not possible. Perhaps a DOS mode restore is.
However I would be booting from the system instal disk. So how do I do a backup
restore? Where are these files kept. How do I do this?
Mark
> etc so
> > Mark
> then we
> it
> > > there.....
> NG's
> am
> disk
> I
> hard
> ware
> the
> with
> the
> components
> a
> disk?
> > > > Mark
Reply to Anonymous
Mark,
Why is a Safe Mode system restore impossible? Is this because you cannot
get to Safe Mode? Regrettably there is no such thing as a DOS mode
system restore although system restore can be run without loading
explorer.exe. All that is possible from DOS is to use scanreg /restore
which can be used to restore one of five backed up copies of the registry
but not any deleted or amended system files.
Mike Maltby MS-MVP
mike.maltby@gmail.com
> is. However I would be booting from the system instal disk. So how do
> I do a backup restore? Where are these files kept. How do I do this?
Reply to Anonymous
Please excuse my previously confusing language. I now understand the
ambiguity.
I meant to suggest what my colleague has previously posted:
Booting to SR using DOS mode
"Depending on the problems you are having, you may be able to use system
restore using the following method which requires you to boot to DOS using
your EBD and editing system.ini and replacing the line
shell=explorer.exe with one reading
shell=C:\windows\system\restore\rstrui.exe
Now remove the EBD and see if you can start Win and boot direct into
System Restore. For more details see KB 279736 "How to Start the System
Restore Tool from a Command Prompt"
(http://support.microsoft.com?kbid=279736) which mentions using
progman.exe after which you can then locate and run rstrui.exe however
using rstrui.exe as above works equally well."
Mike Maltby MVP 5/09/2005
Nevertheless, before doing so, Mark, we FIRST need the answer to Mike's
question about why you can't boot to Safe Mode.
Also, my reference to your system backup files, presupposed that you have
used some third-party backup tool to create same previously. If not, that
possible solution is SOL now.
"Mike M" <No_Spam@Corned_Beef.Only> wrote in message
news:%23%23DxtmVVFHA.3152@TK2MSFTNGP12.phx.gbl...
> Mark,
> Mike Maltby MS-MVP
Reply to Anonymous
This was a nice idea but unfortunatley it didn't work. The error must hit
before systeme.ini loads. As for Mike's question why I can't run in safe
mode. This is hard for me to say. If I knew I might have a solution. I can
olny boot the drive as a slave or boot from the install disk and go to a dos
prompt.
Mark
> ambiguity.
> > Mark,
> > Mike Maltby MS-MVP
Reply to Anonymous
I can only boot with the drive as a slave or through the setup disk for
windows me. Tried scanreg /restore in DOS. IT doesn't seem to work when
booted from the cd.
Mark
Mike M wrote:
> Mark,
> Mike Maltby MS-MVP
Reply to Anonymous
Mark,
Scanreg /restore is not the same as system restore as I'm sure you are
already aware.
I've no idea what doesn't work when booted from a CD. What CD? Microsoft
Win Me CDs aren't bootable however some OEM CDs are bootable as are some
OEM recovery CDs.
If scanreg /restore didn't get your system back up running and you are
unable to launch system restore by modifying system.ini as suggested by
Jack (KB279736) then it looks as if it's time to backup your user data
from that disk and start over.
Mike Maltby MS-MVP
> for windows me. Tried scanreg /restore in DOS. IT doesn't seem to
> work when booted from the cd.
Reply to Anonymous
I am sorry Mike I though I was clear as to "boot from CD" I used a cd to
boot. I didn't think there could be much confusion.
Okay time to start over.
This is a long process and I don't have very good procedures as to what to do
after installing the OS.
I am stuck in no mans land. There are a meriad of programs that I need to
install. First thing I want is email. How do I restore Outlook express?
can I use anything from the old hard drive in terms of the register? I would
like some time in the next year toi actually puting my computer back
together.
To quote Jack Nickelson " I am drowning and everyone wants to describe the
water"
Mark
Mike M wrote:
> Mark,
> already aware.
> OEM recovery CDs.
> Mike Maltby MS-MVP
Reply to Anonymous
way I see it, you ran Norton from a new OS drive and asked it to clean
up an old OS drive.
I'm not privy to what Norton cleanup involves, but I bet a good portion
of all that spyware/virus/adware it found and you had it delete, was
(original disk) system files.
Ya know I been trying to get my Celine Dion CD to boot but nothing
happens... maybe Rush'd do the trick.
Rick
> together.
> water"
> Mark
> Mike M wrote:
>>Mark,
>>already aware.
>>OEM recovery CDs.
>>Mike Maltby MS-MVP
Reply to Anonymous
Mark,
Outlook Express is part of the operating system and will automatically be
installed when you install Win Me. From that comment I'm unclear as to
what you are actually doing and whether you have backed up your data or
not. For example are you clean (re)installing Win Me, that is to a
freshly formatted partition, or reinstalling Win Me over itself? If the
latter then there are a number of gotchas you need to be aware of before
reinstalling Win Me, especially so if you had previously upgraded to IE6
from IE5.5 which is part of the original Win Me install and/or whether you
installed WMP9.
If you've reinstalled Win Me and are asking how to import your backed up
Outlook Express message store, in OE, use File | Import | Messages and
follow the prompts but note that it is essential that the files you are
importing are not marked as read-only, something that will probably have
happened if they were saved to CD-R or CD-RW.
Mike Maltby MS-MVP
> to boot. I didn't think there could be much confusion.
> what to do after installing the OS.
> need to install. First thing I want is email. How do I restore
> Outlook express?
> I would like some time in the next year toi actually puting my
> computer back together.
> describe the water"
Reply to Anonymous
Rush always does the trick but Celine well she's just one big virus on her own.
Mark
BTW I can boot from my install CD so I don't understand the joke.
> up an old OS drive.
> Rick
> > together.
> > water"
> > Mark
> > Mike M wrote:
> >>Mark,
> >>already aware.
> >>OEM recovery CDs.
> >>Mike Maltby MS-MVP
Reply to Anonymous
Well you guys have got me shaking my head. Are you trying to wind me up? I
trust you are trying to help and not just tease me. I don't know what to make
of your reply.
What have I established. Every piece of data from the old drive is still
there except what I need to boot.
If I go forward with a fresh install on a new drive how do I get all my
programs to work without going through the vaery labourious task on
installing every program that I had on the previous drive. Outlook expree was
an example. Sure I have a copy of outlook express on the new system but I
don't have all the emails that I have recieved in the last 10 years. So
Forgive me for trying to do this an easy way and not the hard way.
Mark
Mike M wrote:
> Mark,
> installed WMP9.
> Mike Maltby MS-MVP
> > Outlook express?
> > describe the water"
Reply to Anonymous
"joke" was you didn't say how you were booting (many CDs are bootable...
though I'm guessing Rush wouldn't have worked)... Mike wanted to know if
you were using an M$ CD or a manufacturer-proprietary "Recovery Disk".
I've read your posts and at this point I'm not sure what you're trying
to accomplish; do you want to keep the new drive or revert to the old one ?
Rick
> Mark
>>up an old OS drive.
>>Rick
>>>together.
>>>water"
>>>Mark
>>>Mike M wrote:
>>>>Mark,
>>>>already aware.
>>>>OEM recovery CDs.
>>>>Mike Maltby MS-MVP
Reply to Anonymous
No but from your comments you seem to be a long way from helping yourself.
Just take one example, your question "How do I restore Outlook Express".
Now what exactly is one to read from that? That your system is running OK
but not Outlook Express or perhaps that you have reinstalled Win Me and
now want to import your backed up Outlook Express message store?
I'm sorry but I've decided that I can see little point in my continuing
posting to this thread which just leaves me to wish you the best with
whatever you eventually decide to do.
Oh, and in the meantime why not import those all important ten years of
Outlook Express messages into your working system whilst you are working
out how to proceed. My previous post told you how to do that. At least
then you'd have the satisfaction then of knowing you hadn't lost those
messages.
Mike Maltby MS-MVP
> up? I trust you are trying to help and not just tease me. I don't
> know what to make of your reply.
> still there except what I need to boot.
> my programs to work without going through the vaery labourious task on
> expree was an example. Sure I have a copy of outlook express on the
> new system but I don't have all the emails that I have recieved in
> the last 10 years. So Forgive me for trying to do this an easy way
Reply to Anonymous
Rick,
I'm sorry but I do think it is very clear what I am trying to do. For you to say
that I am being unclear is rediculous. I can't boot with my drive and I am trying to
find solutions. What the hell else do you thinnk I am trying to do! Are you just
trying to wind me up? If there is a recovery product out there then name it. It
breaks my heart every time I look at the posts and find replies that don't move me
any closer to a solution.
Mark
> Rick
> > Mark
> >>up an old OS drive.
> >>Rick
> >>>together.
> >>>water"
> >>>Mark
> >>>Mike M wrote:
> >>>>Mark,
> >>>>already aware.
> >>>>OEM recovery CDs.
> >>>>Mike Maltby MS-MVP
Reply to Anonymous
Mark Garron wrote:
> Rick,
It ain't.
> For you to say
Putting words in my mouth?
You've said that.
> and I am trying to
Dunno; so far you're just one of those jackasses that comes in here
demanding a solution without bothering to say what tools you have at
hand to fix it or what you want to be the final result.
> Are you just
Nope; I have better things to do with my time.
? "Recovery Disk" is a product sold as an OS with some PC's; it's a
cut-down version of Windows, usually dedicated only to the hardware on
that particular model, and much cheaper to license (for the mfr.)
> It
a) I'm generically sorry
b) mind your manners
As far as I'm concerned if you want my help, start a new thread I'm not
inclined to pursue this one.
In the new thread include:
A (four or five line) description of what you consider to be the
problem; this will bring people who aren't following this thread up to
speed.
Another line or two dedicated to what end-result you want ("I want it to
work" is a little vague don't you think?); something like "I want to
keep the old drive and boot from that, and use the new one as a data HD"
or "I want to migrate the OS over to the new HD"
Another couple lines detailing how far you have gotten so far to pursue
what you want ("ran scandisk and fixed the old drive" f'rinstance or
"installed WinME on the new drive", that sort of thing)
And a quick overview of your system: how big are the hard drives, what
are their capacities, how are they partitioned and include what kind of
OS Install media you have: is it a Microsoft produced CD ? What kind:
Upgrade, Full, OEM ("to be sold with a New PC only" ); or is it produced
by the people who put your computer together (brand would help).
ciao for now
Rick
> Mark
>>Rick
>>>Mark
>>>>up an old OS drive.
>>>>Rick
>>>>>together.
>>>>>water"
>>>>>Mark
>>>>>Mike M wrote:
>>>>>>Mark,
>>>>>>already aware.
>>>>>>OEM recovery CDs.
>>>>>>Mike Maltby MS-MVP
Reply to Anonymous
I'm surprised anyone has kept up with this thread considering your
attitude to the people who have tried to help.
Even I with my very limited knowledge of computers would not think it
possible to just copy the registry over, it is made up of many components
which are put there by the OS and programs that are installed.
Why is it you can't just follow Mike's advise with regards clean
installing to the new drive then using the old as backup.
Joan
Mark Garron wrote:
If I can recover a registry from my old
> hard drive on to my new hard drive I would be happy. Again no advice
> seems to be forthcoming.
> Mark
Reply to Anonymous
Rick,
I have taken your advice and reposted. This thread just keeps spiraling away from my
goal of recovering my system.
Mark
Rick T wrote:
> Mark Garron wrote:
> > Rick,
> It ain't.
> > For you to say
> You've said that.
> > and I am trying to
> > Are you just
> > It
> speed.
> ciao for now
> Rick
> > Mark
> >>Rick
> >>>Mark
> >>>>up an old OS drive.
> >>>>Rick
> >>>>>together.
> >>>>>water"
> >>>>>Mark
> >>>>>Mike M wrote:
> >>>>>>Mark,
> >>>>>>already aware.
> >>>>>>OEM recovery CDs.
> >>>>>>Mike Maltby MS-MVP
Reply to Anonymous
Mr. Garron,
no one here is trying "to wind you up", or any other way make your life more
miserable.
We are doing the best we can, using a rather primitive tool from a remote
location, first, to try to understand your situation, and, second, to offer
possible resolutions.
May I, first, and most importantly, suggest to you: "Patience and
persistence", and "There is no excuse for lack of grace under pressure."
Remembering these simple models will make your situation more bearable, and
help us help you better.
1) You are quite lucky that, while the original drive will not now boot to
WinME, it does work as a slave, and your personal data can still be
recovered. Re: your important OE files, Mr. Maltby has posted as to how to
recover them easily. For further documentation, please review
www.insideoe.com, from one the world's leading OE experts, MVP Tom Koch.
Any other valuable personal data should be retrieved to a safe place, ASAP.
2) If you can not restore the WinME boot capability, using scanreg
/restore, nor by using System Restore, AND if you did not prepare for this
eventuality by creating a system OS backup, using a third-party tool, then
you are left with only two choices, as we have repeatedly emphasized to you.
a. An "in-place" reinstallation, which has several critical caveats:
http://winnoel.users.btopenworld.com/reinME.htm
Our colleague here, MVP Noel Paton, is almost certainly the leading expert
for this effort, and you should certainly get his opinion should you choose
this path.
b. A "clean" installation of WinME:
CLEAN REINSTALL OF WINDOWS 98 or WINDOWS ME
Revised May 9, 2005
http://www.aumha.org/win4/a/clean.htm
IMO, since you can still obtain all essential personal data from the
original drive, I recommend the second solution using a new HD for the new
installation. Once all is well, you can use the original drive as a second
drive, for the swapfile and for an archive.
FWIW, I have had to reinstall/recover three WinME installations and deal
with a failing XP SP2 laptop HD in the past 10 weeks.
Despite my considerable expertise, and helpful suggestions from my MVP
colleagues, I simply had to restore a Drive Image 2002 backup of one
unbootable WinME system to recover.
I never did learn why this WinME would only boot to DOS-compatibility
mode -- if/when it would boot -- despite being clean when scanned by the DOS
AV tools, F-Prot and EOD32. Usually, I received "Windows Protection Error.
Restart the machine." or "Error loading Explorer.exe. Please reinstall
Windows" at startup.
The Dual PCI IDE HD controller appeared to be damaged, in Device Manager,
and no effort by me could repair it. I finally installed a second HD and
performed a "parallel" WinME installation to prove that it was not due to a
hardware failure. A subsequent DI backup restoration to the original drive
restored all functionality. I spent four weeks on this problem, out of
curiosity, before giving up. Fortunately, my DI backup was from 3/26/2005,
so I had little to do to fully recover.
Your task, tedious and anxiety-producing as it is, will be far easier.
Please do not hesitate to ask any further, clarifying questions.
HTH,
news:uiWMxqcVFHA.2420@TK2MSFTNGP12.phx.gbl...
> messages.
> Mike Maltby MS-MVP
> > my programs to work without going through the very labourious task on
> > express was an example. Sure I have a copy of outlook express on the
> > new system but I don't have all the emails that I have received in
Reply to Anonymous
Mark,
You have problems not only with your PC but also seemingly in reading and
comprehending what you have been told by myself and others in this thread.
My advice to you now is to seek professional help from someone who will
restore your PC to a working condition. Just be prepared to pay out real
money and not to be rude to them as you might well find them doubling
their charges.
Mike Maltby MS-MVP
> Mike just to get this clear...
> Your solution is to reinstall all my programs one at a time a task
> that will probably take a a day or two may be more. Is that what you
> are suggesting. Understand that I was looking for the best practise
> re this kind or problem. I still believe there is a solution and I
> was looking for the solution. Forgive me for not being thrilled at
> the prospect of reinstalling everything.
> As for Outlook express. Have you copied from one drive to another? The
> process does take time and is far from fun.
> You said..."I have already repeatedly told you how to solve"
> You hinted at a solution in an earlier post but when I try to pursue
> you go off on tangent now you are obsessed with Outlook express and
> not my registry. Forgive me but recovering my registry was the alpha
> and omega of this problem. If I can recover a registry from my old
Reply to Anonymous
Jack,
I have to say thank you. This is the best response that I have recieved. It is
clear you understand my problem and you have gone out of your way to point me
is very interesting and important avenues of research. At the very least I will
feel confident that I have expolored all avenues before choosing the path to
recover that is best suited for me.
Again thank you! thank you! thank you!
Mark
> Mr. Garron,
> miserable.
> this path.
> Revised May 9, 2005
> HTH,
> > messages.
> > Mike Maltby MS-MVP
Reply to Anonymous
Joan,
The reason I started this thread in the first place to avoid having to do
this. I wrote this as my primary goal in my first post.
Mark
> Joan
> > Mark
Reply to Anonymous
I am very pleased with your response here, and hope our aid comes to be
really useful to you.
May I point out that I have said little-to-nothing else than my colleagues
have previously noted.
We all intend you well. We think we can help you, too, despite our various
ways of attempting to do so..
It is critical that we all remember that we are a fragile community of
like-interested souls, using a minimally-communicative tool, but facing
computer problems which can be quite complex and anxious, and affording many
opportunities to lose our patience and better manners. This can be true for
responders as well as OP's. All misunderstandings about motives must be
laid aside in the interests of good will and success. No one can be here
long without increasing their moral development.
I commend you, and recommend that you continue seeking your solution at your
newer post, where I see you already have some responses.
I wish you the very best, knowing that we (the several of us) can resolve
your problem together,
news:4282155D.F8AAD3DE@xigo.com...
> Jack,
> I have to say thank you. This is the best response that I have received.
It is
me
> is very interesting and important avenues of research. At the very least,
I will
to
> Mark
> > Mr. Garron,
more
> > miserable.
remote
offer
pressure."
and
to
to
ASAP.
this
then
you.
caveats:
expert
choose
> > this path.
> > Revised May 9, 2005
new
second
DOS
Error.
reinstall
Manager,
to a
drive
of
3/26/2005,
> > HTH,
yourself.
Express".
running OK
and
continuing
of
working
least
> > > messages.
> > > Mike Maltby MS-MVP
on
Reply to Anonymous
Tom's Hardware > Forum > Windows 95/98/ME > General Discussion > hard drive problems
There are 2011 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Need insight on my pc with windows 98 OS
By wombat_tg, 4 days ago:
You will need a dial-up account with an ISP in order to make use to that modem. (You're...
Best offers
Top experts
