Archived from groups: microsoft.public.windowsme.general (More info?)
I posted this by mistake on the 98 ng, and got one good
reply. I'm reposting here because this is the correct
forum.
Yesteday, for some reason, my computer (ME) went kaput,
and I couldn't
boot even in Safe Mode. I used a boot disk for system
restore, and the
date given was in June 2004. I was able to boot up then,
but Norton
wasn't able to be activated. The system trail had
nothing, and I got
the mouse and sound in it manually. I checked "msconfig"
and it had
"Selected Start-up" but had everything I needed. I had
downloaded Jin
for start up, so I clicked on "general start-up."
However, it did not
take and every time I rebooted, the run did not
read "msconfig" but
"inetwiz," which I needed to get back on my Comcast cable
internet.
Taking the advice from this group, I downloaded the AVG
virus detector,
and will remove Norton. However, my problem now is that I
can't get
systray to load properly. I removed "jin" so I really
need that
website again. I removed it because it was unable to
work. JavaScript
is not working, and I got this message: Unable to locate
registry
hkey_local-machine\software\Java Script\Java Plug-
In\1.4.2.06. I tried
typing in that key in the registry, but it would not take
due to
unacceptable symbols.
My Outlook Express went to ground zero and I've lost all
my contacts,
also. Every download I did since June 04 is on my
computer, just that
they don't work, including WinZip.
Any suggestions?
First off - NO-ONE in this group would have advised you to use System
Restore to go back 11 months!!
The most that should normally be considered is about 2 WEEKS!!
The reason that you have lost many of your programs is very simple - they
have been uninstalled by your recklessness.
System Restore does exactly what it's told to do - and you told it to
restore not only the registry, but also the programs installed correctly, to
a date which is, IMHO, totally without precedent!!
Were there no later dates? - if so, why did you not use them?? If not, why
did you not query the situation at that point??
SR, when functioning properly, creates a Restore Point every 10 hours of
system uptime - or every 24hours real-time.(assuming that the system is idle
for a few minutes).
<rant over>
Where to go now? If you can't undo the Restore (and I suspect that that will
be the case), you have to Uninstall Norton software completely - it will
otherwise complain bitterly at every move you make (especially at boot).
If you're lucky enough to be able to undo the Restore, then do so, and post
back with the EXACT symptoms of your problems as they exist then,
Either way, we will need a LOT of detail as to error messages, and your
actions at the time of the messages, to be able to cure the problems.
Noel Paton (MS-MVP 2002-2005, Windows)
Nil Carborundum Illegitemi
http://www.btinternet.com/~winnoel/millsrpch.htm
http://tinyurl.com/6oztj
Please read http://dts-l.org/goodpost.htm on how to post messages to NG's
"Irving Rosenfeld" <anonymous@discussions.microsoft.com> wrote in message
news:178601c554c7$f06345b0$a401280a@phx.gbl...
forum.
and I couldn't
restore, and the
but Norton
nothing, and I got
and it had
downloaded Jin
However, it did not
read "msconfig" but
internet.
virus detector,
can't get
need that
work. JavaScript
registry
due to
my contacts,
computer, just that
Any suggestions?
If you restored to a checkpoint nearly a year old you are bound to be
seeing problems although you would see them whatever date you returned to
if you have the NAV virus on your system.
System Restore will not have touched your address book or your message
store as it has no interest in files with a wab or dbx extension in the
same way that system restore doesn't monitor changes to other data files
such as those with doc, xls, ppt, jpg, mp3 or avi extensions. Use search
and see if you can locate you original message store and it located you
will probably be able to import it into your new identity.
It appears that as a result of using system restore you have reverted to a
very old copy of the registry. You may be able to recover from that by
using scanreg /restore provided that you did not have the scanregw entry
disabled in MSConfig | Startup. By running scanreg /restore from a
command prompt or by entering it in Start | Run and clicking OK you should
hopefully be able to restore a recent copy of the registry although it
will be well out of synch with your system files due to your having
earlier restored to June 2004.
I suspect you have a lot of system building in front of you and a number
of applications to reinstall.
Best of luck,
Mike Maltby MS-MVP
mike.maltby@gmail.com
> forum.
> and I couldn't
> restore, and the
> but Norton
> nothing, and I got
> and it had
> downloaded Jin
> However, it did not
> read "msconfig" but
> internet.
> virus detector,
> can't get
> need that
> work. JavaScript
> registry
> due to
> my contacts,
> computer, just that
> Any suggestions?
>> I used a boot disk for system restore, and the date given was in June
2004.<<
Could it be that you just did a registry restore?
Could you ellaborate in more detail on what you did exactly while using the
boot disk?
Zee
Zee,
My question exactly. The poster has mailed me direct as they are unable
to get back to the newsgroup and as well as giving them a link to enable
them to use OE to access this NG I also asked them to post precise details
of what they did.
Mike Maltby MS-MVP
> using the boot disk?
Mike,
Good.
Let's hope he can get back to the NG.
Zee
"Mike M" <No_Spam@Corned_Beef.Only> wrote in message
news:%23yTQx3NVFHA.2116@TK2MSFTNGP09.phx.gbl...
> Zee,
> of what they did.
> Mike Maltby MS-MVP
Well, I finally managed to get to send a reply, but I
couldn't do it through OE. I went to the Micrsoft
Newsgroups web page.
I guess that's what I did. The boot disk told me to
type "scanreg /restore," which restored my registry to
June 2004. The only recent restore dates are today, which
would do me no good, as I did that yesterday. Now I can't
delete all those downloads because I'm missing the
registry key and I can't download them again until I
delete them.
>-----Original Message-----
bound to be
you returned to
your message
extension in the
other data files
it located you
have reverted to a
scanregw entry
your having
you and a number
>Best of luck,
>Mike Maltby MS-MVP
>> forum.
>> and I couldn't
>> restore, and the
then,
>> but Norton
>> nothing, and I got
checked "msconfig"
>> and it had
>> downloaded Jin
>> However, it did not
>> read "msconfig" but
cable
>> internet.
>> virus detector,
that I
>> can't get
>> need that
>> work. JavaScript
>> registry
take
>> due to
>> my contacts,
>> computer, just that
>> Any suggestions?
If you don't have system restore checkpoints for the last few dates you're
SOL. As to having no more recent copy of the registry than June 2004 this
is usually the result of having unchecked the scanregw entry in MSConfig |
Startup. Since you have a system now running with a year old copy of the
registry I feel you have a major task on your hands to get the system back
running as it should be.
As for your OE problems if you were to answer some of the questions I have
asked you perhaps we could get the problem sorted out but to date you
don't appear to want or perhaps be able to answer.
Mike Maltby MS-MVP
> delete them.
State Mgr manages System Restore, and I've always kept
that as a start up. I think it's because I also had
Norton's GoBack running, it did not properly create
restore points. I don't know why. I've tried to answer
your questions. I clicked on your link and it gets me to
OE ng here, but I cannot reply to the group since I get
the message that the OE is not configured correctly. One
time, and I don't recall how I did it, I managed to type
in my name and fake email address, but I still couldn't
post.
bound to be
you returned to
your message
extension in the
other data files
it located you
have reverted to a
scanregw entry
your having
you and a number
>Best of luck,
>Mike Maltby MS-MVP
>> forum.
>> and I couldn't
>> restore, and the
then,
>> but Norton
>> nothing, and I got
checked "msconfig"
>> and it had
>> downloaded Jin
>> However, it did not
>> read "msconfig" but
cable
>> internet.
>> virus detector,
that I
>> can't get
>> need that
>> work. JavaScript
>> registry
take
>> due to
>> my contacts,
>> computer, just that
>> Any suggestions?
I didn't have anything in the Name and Address fields, but I filled it with
fake names now. See if it goes.
news:%23SYhdzOVFHA.1040@TK2MSFTNGP10.phx.gbl...
> Mike Maltby MS-MVP
> > delete them.
Well done!
That's all that appears to have been necessary which is what OE's message
was telling you when it said "No sender specified".
Mike Maltby MS-MVP
> it with fake names now. See if it goes.
GoBack and System Restore are incompatible. It's one or the other, you
can't use both.
Mike Maltby MS-MVP
> post.
Mr. Rosenfeld doesn't appear to like (or be able to effectively use) the
advice he is getting here any better than that I gave him in
....windows98.general previously, ... other than to post here instead.
I suspect he is simply going to have to reinstall many apps to recover.
I suggested he use the IE repair tool in Add-Remove Programs, and I see no
evidence he has attempted to do so yet.
Jack E. Martinelli 2002-05 MS MVP for Shell/User / DTS
Help us help you: http://www.dts-L.org/goodpost.htm
In Memorium: Alex Nichol
http://www.microsoft.com/windowsxp [...] ichol.mspx
Your cooperation is very appreciated.
"oops!!" <notme@nowhere.com> wrote in message
news:epZVk8NVFHA.3424@TK2MSFTNGP09.phx.gbl...
> Mike,
> Good.
> Zee
> > Zee,
details
> > of what they did.
> > Mike Maltby MS-MVP
Thanks for the advice. I've tried to reinstall many apps, but many do not
take. When I clicked on IE6 in the Add/Remove Program, I get a warning that
this will delete my IE and do I want to continue. Are they lying to me?
"Jack E Martinelli" <jemartin_DELETE@NO_SPAM_gis.net> wrote in message
news:ehviOYRVFHA.1376@TK2MSFTNGP10.phx.gbl...
> > Mike,
> > Good.
> > Zee
> > > Zee,
unable
enable
> details
> > > of what they did.
> > > Mike Maltby MS-MVP
The earliest date given in scanreg /restore is on 5/8 at 10:28 PM, which is
after my problems began. I note that when I tried to re-download Belarc, I
get the following error messages: "\System\tmp\/ASc2c4 contains an invalid
path" and "\System\tpl\site Default Summary contains an invalid path". I am
also unable to re-download Java. I thought that may be due to a registry
key being missing, and it may, but could it also be an invalid path. If so,
is there any way to repair it? Apparently I have no way to restore any
missing registry key.
news:eFrNnsMVFHA.628@tk2msftngp13.phx.gbl...
> Best of luck,
> Mike Maltby MS-MVP
> > forum.
> > and I couldn't
> > restore, and the
> > but Norton
> > nothing, and I got
> > and it had
> > downloaded Jin
> > However, it did not
> > read "msconfig" but
> > internet.
> > virus detector,
> > can't get
> > need that
> > work. JavaScript
> > registry
> > due to
> > my contacts,
> > computer, just that
> > Any suggestions?
Your error messages appear to be referencing files in the temporary
directories, which files and directories are probably now missing.
Clean out all IE caches, uninstall Belarc and the Sun Java, if installed,
and reattempt the DL's for the setup files. If successful, run the
installations. The Sun Java file will install ver. 1.4.2_08, and when it is
running, use its Help/Update wizard to update to ver. 1.5.0_02.
N.B. The two Sun Java setup files are ca. 15 MB, so any dial-up DL will
take quite some time.
"Someone" <someone@comcast.net> wrote in message
news:eF8wXAbVFHA.3808@TK2MSFTNGP14.phx.gbl...
is
I
invalid
am
so,
to
search
a
should
> > Best of luck,
> > Mike Maltby MS-MVP
> > > forum.
> > > and I couldn't
> > > restore, and the
> > > but Norton
> > > nothing, and I got
> > > and it had
> > > downloaded Jin
> > > However, it did not
> > > read "msconfig" but
> > > internet.
> > > virus detector,
> > > can't get
> > > need that
> > > work. JavaScript
> > > registry
> > > due to
> > > my contacts,
> > > computer, just that
> > > Any suggestions?
Open IE and confirm that ver. 6 is installed using the Help / About Internet
Explorer tab.
If so, selecting the Microsoft IE6 ... item in Add-Remove Programs, and
choosing Remove, will pop up a window with three options:
1) Add a component
2) Repair IE
3) Restore the previous Windows configuration
In addition, there is a "Advanced" button, which will show the various IE
and OE components and Win Updates currently installed.
This permits reverting one or more components separately... not usually
advisable.
Also, an option to delete the past configuration information; doing so will
preclude reverting to the the past installation/s.
Re: failed attempts to reinstall many other apps:
First, use the Add-Remove Programs wizard to uninstall the currently damaged
installation. Then reinstall and update, as needed.
news:eB$F%23DaVFHA.2256@TK2MSFTNGP14.phx.gbl...
that
<SNIP>
I cannot use the Add/Remove program to uninstall damaged installations
because they are not listed there.
news:%23IiYxoiVFHA.1376@TK2MSFTNGP10.phx.gbl...
Internet
> Explorer tab.
> 1) Add a component
> 2) Repair IE
> advisable.
will
damaged
not
> that
> <SNIP>
That suggests the necessary uninstall files have been removed. Now find the
(partially empty) folders for the missing programs and delete them.
Proceed with the IE6 repair option, if it is available.
news:ulfr8%23lVFHA.2768@tk2msftngp13.phx.gbl...
> > Internet Explorer tab.
> > 1) Add a component
> > 2) Repair IE
IE
> > advisable.
> > will preclude reverting to the the past installation/s.
> > damaged installation. Then reinstall and update, as needed.
> > not take. When I clicked on IE6 in the Add/Remove Program, I get a
warning
> > that this will delete my IE and do I want to continue. Are they lying
to me?
> > <SNIP>
dear sir,madam
can anyone help me my daughters computer has a problem i need a emergency
floppy disk and i have no idea where i can get one for windows me as her
computer is asking for it .she received her computer for her wish from the
make a wish foundation here in australia and they did not send her the
disket .i would be gratefull if anyone can help me
thank you
chrisie
Chrisie,
You can create a boot floppy (EBD) or start up disk as follows:
Control Panel | Add/Remove Programs | Startup Disk and follow the prompts.
If you get asked for the location of a "missing" file point the wizard
towards the Win Me cab files which should be in either the
windows\options\cabs or windows\options\install folder. Alternatively
point to the Win9x folder on the Win Me CD. Specifically look for the
file BASE2.CAB and then point the wizard at the folder containing
base2.cab..
If you are unable to create a boot floppy you can download the image of a
Win Me OEM boot disk from www.bootdisk.com. Download to your desktop,
double click to run and follow the prompts to transfer the image to a
floppy. Do NOT copy the downloaded file to a floppy - that won't make a
bootable floppy but instead a floppy disk containing the file you
downloaded.
Mike Maltby MS-MVP
christine easton via WindowsKB.com <forum@WindowsKB.com> wrote:
> dear sir,madam
> emergency floppy disk and i have no idea where i can get one for
> windows me as her computer is asking for it .she received her
> computer for her wish from the make a wish foundation here in
> australia and they did not send her the disket .i would be gratefull
> if anyone can help me thank you
> chrisie
There are 1218 identified and unidentified users. To see the list of identified users, Click here.
