Archived from groups: alt.comp.hardware,alt.comp.hardware.pc-homebuilt (More info?)
I have owned 3 MCK-142PRO keyboards. Each has failed in about 2
years. The Enter key on my current one failed last night. the key
seems to have broken off it's base. I think this is the way both my
earlier ones failed. These things cost $100+. Is there a way to
repair this?
>repair this?
>Here's a photo of the broken key http://factsfacts.com/keyboard.jpg
Thanks for the picture.
Here is the whole thing:
http://tinyurl.com/5kjbu ADESSO CAD PROGRAMMABLE 142 KEY KEYBOARD
I can't really tell what is broken, since there is no fully
functioning part to compare it to.
Of course, one way to avoid the problem is by a different keyboard. I
guess you probably don't want to learn new function keys.
If you buy another keyboard, if you touch type, buy a split keyboard.
The more split the better, in my opinion. I think Logitech makes good
keyboards.
Good luck.
United States and British intelligence agencies admittedly break the
law while spying on each other. United States and British governments
claim to actively share that illegally gathered intelligence.
On Sat, 05 Feb 2005 22:42:01 GMT, John Doe
It's more than just learning them it's taking my eyes off what I'm
doing to reach them. The function keys on the left is a MUCH better
solution. Why this style was abandoned for the much clumsier,
difficult to use row across the top of the keyboard is a mystery to
me. Also, this keyboard also has 24 key which will memorize different
keyboard macros.
>> keyboard. I guess you probably don't want to learn new function
>> keys.
>better solution. Why this style was abandoned for the much
>clumsier, difficult to use row across the top of the keyboard is a
>mystery to me.
I guess they wanted less width and more depth.
>keyboard macros.
Macros are my Window's forte. I think Macro Express is pretty good
(or was, I write my own recorder nowadays). Stay away from QuickKeys
for Windows. There is also speech recognition if you can afford it.
Dragon's NaturallySpeaking 7 Professional includes single window
macros (not systemwide macros). Even simple replacement text style
NS7 Preferred voice macros are surprisingly very useful. If you do
Computer Aided Design, also try some of the big CAD discussion
groups for keyboard suggestions.
governments claim to actively share that illegally gathered
intelligence.
On Sun, 06 Feb 2005 00:16:04 GMT, John Doe
>>> keys.
>>mystery to me.
Not really. They took away two columns of keys (the F keys) on the
edge of the keyboard and added three columns (cursor pad) in the
middle. The original PC keyboard was narrower (less wide) than the
one that replaced it -- the one with the F keys along the top and the
cursor pad between the letter keys and the cursor/number pad on the
right.
>>>> keys.
>>> mystery to me.
>right.
Assuming that is true. Because they wanted to add a keypad, and naturally placed it on the right side which increased the width, you are led to the conclusion that they moved the function keys just to inconvenience you? Whatever.
I for one appreciate your post about problems with your ADESSO keyboard. The picture is useful. Then again, if by being there you can't tell what's broken, how is anyone else going to tell? Have you removed another key so you can compare the two?
