Latest Reviews & Articles
Reader's Voice: An Introduction To Home Automation
Perhaps you've heard about Bill Gates' remote-controlled home and thought to yourself that the technology to automate your own home was decidedly out of reach. Today, Tom's Hardware reader John Knutson walks us through what it took to get his home wired. Read more
Perfect Notebook Storage: Seven 2.5” 500 GB Drives
We compare the latest 500 GB notebook drives from Fujitsu, Hitachi, Samsung, Seagate, Toshiba and WD. Seagate is first manufacturer to reach 500 GB at 7,200 RPM, but which is really the best drive? We loaded up our updated test system to find out. Read more
Mainstream Graphics Card Roundup
You don’t always need the fastest graphics card around. For somewhere between $135 and $235, you can game like crazy in DirectX 10 without a problem at 1920x1200. We test and compare five graphics cards from this mid-range price segment. Read more
USB 3.0 Ups Peripheral Bandwidth
The new USB 3.0 interface is just about ready. It'll accelerate throughput from the 480 Mbit/s of today's USB 2.0 to 5 Gbit/s, which is important for storage and peripheral devices. But USB 3.0 also introduces power saving options. Read on for more. Read more
All the Reviews & Articles
Netgear ds108 problem
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
hi there i recently bought a ds 108 now i'm trying to run my broadband
into it and the from it to my second pc and xbox problem is when i
first turn on my 2nd computer which has a cat 5 cable running from it
to the hub the light on the hub will light up great but after after a
few mins it goes out and therefore isnt sending the broadband to the
pc the uplink is working fine,
does any1 know what the problem could be
thanks
Sponsored Links
either the NIC in the machine, the Hub or the Cable is going bad.
When the 'led' goes out on a router or a switch, this generally means
there is no connection at all. I would check the cable first. try
another port.
"stephen" <skane2000_uk@yahoo.co-dot-uk.no-spam.invalid> wrote in
message news:4205e070$1_5@alt.athenanews.com...
broadband
it
a
> thanks
Reply to jad
- 0 +
but would it light up and the go out if it was the hub or cable, maybe
it the nic as u say
Reply to Stephen
- 0 +
hi again ok i tried wiring up my xbox to this hub and it seem to be
getting the internet connection ok, so at the min the hub is getting
the connection into it and will send it out to the xbox but when i
connect a ethernet cable from hub to 2nd pc the lights go out and no
connection is found now the ethernet card in the 2nd pc is only new
and if i run a ethernet cable direct into it, it works fine but when
i trying running through hub it doesnt work
does any1 know what the problem could be is there any settings i have
to change on the pc windows 98
cheers
Reply to Stephen
- 0 +
x box needs cross over cable?
"stephen" <skane2000_uk@yahoo.co-dot-uk.no-spam.invalid> wrote in message
news:420b96f0$1_2@alt.athenanews.com...
> cheers
Reply to jad
Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Netgear ds108 problem
There are 689 identified and unidentified users. To see the list of identified users, Click here.
You are about to answer a thread that has been inactive for more than 6 months. If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread. Add a reply Cancel
Sponsored links
