G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Hi, I have an Abit NF7-S motherboard and am using the built-in audio
ports. I am trying to hook up a Logitech Z-640 speaker set, a 5.1 system.
Accoring to the Abit manual:
green = front left/right
orange = rear left/right
black = center/sub
The Logitech setup guide however doesn't get specific. They just say
"hook up the green/orange/black plugs to your sound card's corresponding
inputs". Okay, sounds easy, right? The problem is that when I do this
I get no sound from my rear speakers.
I should mention that I have checked the audio preferences in Windows
and selected a 6-speaker setup. I've also moved the individual speakers
around and connected them to different ports on the subwoofer, so I know
all the speakers are operational. I also know all the sound ports on
the motherboard work because I've moved the plugs to different inputs
and am able to get at least some sound. But I just can't get everything
right.
I was wondering how best to troubleshoot this. Are there any utility
programs that can send sound to individual speakers so you can see that
selecting "rear right" sends a sound to the rear right speaker for
example? Thanks.
black = center/sub
right.
example? Thanks.
