Archived from groups: microsoft.public.windowsme.general (More info?)
I bought a USB drive (Handy Steno HT202) that said it was compatible with
WinME and didn't need any other driver. When I insert it, it causes the blue
screen. The error is: 0D : 0028 : 00000003.
In Device Manager it shows up in a separate section (not under the USB
controller). Its status has Code 11, and suggests looking at ASD and
upgrading the device driver. If I upgrade the driver, windows says it already
has the best one installed.
ASD says: windows had a problem while attempting to start your: USB disk.
The reference is: USBSTOR\DISK&VEN_&PROD_USB_FLASH_DRIVE&RE [the rest is
truncated]. It also suggests upgrading the driver or changing resources.
I have run msinfo32.exe to look at hardware conflicts and the only ones are
IRQ holders that are on the same IRQ (10) as the USB drive. I tried turning
off PCI steering, but that didn't resolve that conflict.
You haven't told us if USB 2.0 is enabled on the machine, in addition to the
earlier USB 1.0 or 1.1.
If so, there should be separate listings for the two types of USB
controllers in Device Manager, and they should all be UnMarked.
Jack E. Martinelli 2002-05 MS MVP for Shell/User / DTS
Help us help you: http://www.dts-L.org/goodpost.htm In Memorium: Alex Nichol
http://www.microsoft.com/windowsxp [...] ichol.mspx Your cooperation is very appreciated.
"mdf" <mdf@discussions.microsoft.com> wrote in message
news:FA3B1900-894A-42F8-A656-CA67C4CA7547@microsoft.com...
blue
already
are
turning
> Can anyone help please?
The device Manager lists it as INTEL 82371AB/EB PCI to USB Universal Host,
hardware vers. 001. I suppose this is USB 1.0? The flash drive is USB 2.0,
but said it is compatible with USB 1.0 and 1.1.
> Help us help you: http://www.dts-L.org/goodpost.htm > In Memorium: Alex Nichol
> http://www.microsoft.com/windowsxp [...] ichol.mspx > Your cooperation is very appreciated.
and try searching the KB for other "USB" articles - there are quite a few!.
Might also be worth 'Removing' any/USB Devices and Drivers shown in Device
Manager when in Safe Mode and rebooting to let WinMe re-install the USB
controllers again.
In the meantime you might find this useful :-
If you have a copy of the Win98 CD, then see the following URL and try the
usbview.exe on the CD (NB It's not on the WinME CD) and see if you are able
to determine whether it recognises the controllers correctly.
"How to Use the Windows 98 USB Device Viewer Utility"
http://support.microsoft.com/defau [...] -us;272584
news:40D620C4-B9C5-43F6-8C3A-3F02F21981B7@microsoft.com...
>> the
>> Help us help you: http://www.dts-L.org/goodpost.htm >> In Memorium: Alex Nichol
>> http://www.microsoft.com/windowsxp [...] ichol.mspx >> Your cooperation is very appreciated.
Very nicely done, Mart.
I suspect mdf will discover that his USB 1.0/1.1 system is running fine, but
the new flash device is causing the BSOD.
A different vendor's tool will be needed.
"Mart" <mart(NoSpam)@nospam.nospam> wrote in message
newsXcfifiYFHA.3648@TK2MSFTNGP14.phx.gbl...
> You are correct, the flash drive *should* be backward compatible with USB
> 1.0 and 1.1.
> Try the following KB article :-
> "General USB Troubleshooting in Windows 98, Windows 98 Second Edition, and
> Windows Me."
> http://support.microsoft.com/defau [...] -us;263218 >
few!.
> controllers again.
able
> http://support.microsoft.com/defau [...] -us;272584 >
> You can download usbview.exe from:
ftp://ftp.microsoft.com/services/ [...] SBVIEW.EXE >
> Mart
Host,
2.0,
to
> >> the
> >> Help us help you: http://www.dts-L.org/goodpost.htm > >> In Memorium: Alex Nichol
> >> http://www.microsoft.com/windowsxp [...] ichol.mspx > >> Your cooperation is very appreciated.
