Tom's Hardware > Forum > Games General > Games General Discussions > Logitech Joystick issue, thoughts on possible replacement ?
Forum Games General : Games General Discussions - Logitech Joystick issue, thoughts on possible replacement ?
Archived from groups: alt.games.microsoft.flight-sim (More info?)
Hey Everyone,
I've been having an issue with a Logitech Extreme 3D Pro joystick for a
while now. I've recently confirmed the problem on my gliding simulators. I
had to replace my mother board a few weeks back so I haven't re-installed
FS2004 and all my add-ons yet. When I plug the joystick in the calibration
is fine and has full movement. A few minutes into the sim movement to the
right and right rudder becomes limited and hardly moves. I've done a web
search and this appears to be a common thing with Logitech controllers. I've
tried uninstalling the Logitech software which allows manual calibration.
After a few minutes into the sim the same thing happens reduced movement to
the right. Pushing left gives full movement. The only cure I've found is to
keep unplugging/re-inserting the usb to reset it.
I was wondering if anyone knows of a fix that works. OR can recommend a
replacement joystick that they've found to be reliable. I've had the Extreme
about 2 years now. The only thing is I'm left handed so I'd be looking for a
stick/buttons that are comfortable with either hand.
Any thoughts would be great.
Cheers,
Rick
Sponsored Links
I have a Logitech Wingman Force 3D joystick which I've been using for a
couple of years and I find it works very well with FS9. The twist handle
controls the rudder from one side to the other as well as ground steering
and the other axis' work equally as well. If I had any complaint about the
stick at all, it would be the amount of play which has developed, which I
think is due to the force feedback feature (which I feel is not a necessity
for simming). I wish there was a way I could tighten the handle and
eliminate the play, but there doesn't seem to be anywhere I can do this.
I can't recommend a 'fix' but will suggest you make every effort to solve
the problem without replacing the joystick. I have a notion it's a software
adjustment, either in your machine or FS9, which you may incur even with a
new joystick. I suppose you could go out and buy another one and test it on
your machine.....if it's better, that's great.
Good luck,
Arthur
"Rick Blythin" <newsgroup_post@yahoo.ca> wrote in message
news:Nm9Qd.2000$dZ.161249@news20.bellglobal.com...
> Hey Everyone,
> I've
> to
> to
> Extreme
> a
> Cheers,
> Rick
Reply to Arthur
> a couple of years and I find it works very well with FS9. The twist
> handle controls the rudder from one side to the other as well as
> ground steering and the other axis' work equally as well. If I had
> any complaint about the stick at all, it would be the amount of play
> which has developed, which I think is due to the force feedback
> feature (which I feel is not a necessity for simming). I wish there
> was a way I could tighten the handle and eliminate the play, but
> solve the problem without replacing the joystick. I have a notion
> it's a software adjustment, either in your machine or FS9, which you
> may incur even with a new joystick. I suppose you could go out and
> buy another one and test it on your machine.....if it's better,
> that's great.
> Good luck,
> Arthur
>> Hey Everyone,
>> for a while now. I've recently confirmed the problem on my gliding
>> simulators. I had to replace my mother board a few weeks back so I
>> haven't re-installed FS2004 and all my add-ons yet. When I plug the
>> joystick in the calibration is fine and has full movement. A few
>> minutes into the sim movement to the right and right rudder becomes
>> limited and hardly moves. I've done a web search and this appears to
>> calibration. After a few minutes into the sim the same thing happens
>> reduced movement to
>> found is to
>> recommend a replacement joystick that they've found to be reliable.
>> looking for a
>> Cheers,
>> Rick
I had a Logitech stick for a while - once it was out of warranty, Logitech
were not interested; same fault as Rick. I eventually solved it by buying a
Saitek stick. No more problems.
Cheers
Ches
Reply to Anonymous
>Saitek stick.
Which model?
Thanks,
Phil
"Rita" <rita@lineout.net> wrote in message
news:uKhQd.97663$B8.20119@fe3.news.blueyonder.co.uk...
>> that's great.
>> Good luck,
>> Arthur
>>> Hey Everyone,
>>> reduced movement to
>>> found is to
>>> looking for a
>>> Cheers,
>>> Rick
> a
> Cheers
> Ches
Reply to Anonymous
There are 1061 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
