Archived from groups: comp.periphs.printers (More info?)
I have a HP 6657 (#57 tricolor) cartridge, which has been refilled once
(ONLY ONCE) successfully. The first refill worked perfectly, no issue's
whatsoever.
When I tried to refill it again, I started getting massive banding. So I
tried to clean the print heads, though as I see it now- they do not need
cleaning- even now. I ran the jets under water, I let the cartridge sit in
a tiny level of hot water for a few minutes (enough to cover the jets only),
I tried using the head cleaning that came with my ink refill kit, paper
towels to wick the ink from the jets and many cleaner pages, primer pages,
etc. All of which worked (I guess), since I am able to get ink from the
cartridge, but not in high quality mode.
If I print to NON-PHOTO ink jet paper, the cartridge seems to print ok. But
when I try to print in normal/best quality to glossy photo paper, I get
banding after 1 min or less of printing. I printed my wife some business
cards, on "other inkjet paper" setting, in best mode- 100% perfect. I tried
printing a photo on premium glossy photo paper best mode, and got severe
banding
I'm at my wits end with this cartridge. I'm stunned to see it print to
plain/other inkjet papers- but not to photo paper correctly.
Can anyone give me some advice, before I trash this cartridge?
whatsoever.
banding
