Archived from groups: microsoft.public.windowsme.general (More info?)
Is there a command that will force the monitor to power down
the way Windows ME does in the Screen Saver/Settings/Turn
off monitor box? Yes, I can just turn it off, but I'm told
that doing it this way will have a negative affect on its
life. So I'd like to either enter a command or set up a key
stroke combination that will run the command. Also, will
this work with the WinMedia player running?
"Dave Boland" <NODARNSPAMdboland9@stny.rr.com> wrote in message
news:fpGpe.9361$HT1.8568@twister.nyroc.rr.com...
> Is there a command that will force the monitor to power down the way
> Windows ME does in the Screen Saver/Settings/Turn off monitor box? Yes, I
> can just turn it off, but I'm told that doing it this way will have a
> negative affect on its life. So I'd like to either enter a command or set
> up a key stroke combination that will run the command. Also, will this
> Thanks,
> Dave
> Thanks,
> Dave
