Archived from groups: microsoft.public.windowsme.general (More info?)
Which version of jv16 are you using?
Clark
"KB" <KB@discussions.winme> wrote in message
newsvZX1EjbFHA.2688@TK2MSFTNGP14.phx.gbl...
> Played with easy cleaner for a couple months now. Been warmin up jv16 but
> having some technical difficulty.
> I've tried to clean up the 250+ registry entries but when I hit the
> 'remove'
> button, nothing happens. Just sits there.
> Starting programs at 17. All legit to me.
> Also, how many registered file types are typical? 458?
> And shell extensions? 545?
> And installed software? 157? (all seem legit)
> What's ok to cleanout? Those marked safe to delete and/or unknown?
> File Tool found 0/24229 at the bottom left corner.
> Then it stopped responding. Hmm.
> HeirloomXP, are 'ya out there?
> KBMe
KB wrote:
<jv16>
> I've tried to clean up the 250+ registry entries but when I hit the 'remove'
you have to Select the ones you want to Delete, first. Maybe selecting
"Auto" in Options might do the trick.
depends what you've done... I haven't had any problems running the
Registry Cleanup with 4.3; ditto the initial page... I just delete stuff
that I don't want.
1.3.0.195
"Clark" <who@whoknows.com> wrote in message
news:LfBqe.2513$I14.196@newssvr12.news.prodigy.com...
> Clark
but
> > 'remove'
> > KBMe
I hit the delete key instead of the 'remove' button and it worked.
My version is 1.3.0.195.
KB
"Rick T" <plinnane3REMOVE@NOSPAMyahoo.com> wrote in message
news:eaRQArpbFHA.3200@tk2msftngp13.phx.gbl...
> KB wrote:
> <jv16>
'remove'
> that I don't want.
> Rick
I had some problems running an earlier version with WinXP. I am now using
V1.5 which I downloaded to try. I have already seen some strange behavior
but will keep checking for another week or so to make sure. I really liked
the original RegCleaner, it did something that I am having trouble finding
in the newer products.
They say there is another update to 2005 version soon, but I do see when.
As far as what is ok to remove, the website says they think the program is
safe, but will not guarantee something important will not be removed. It
says something about Intelligent usage.
Clark
news:erSnoBrbFHA.3200@tk2msftngp13.phx.gbl...
> 1.3.0.195
>> Clark
> but
>> > 'remove'
>> > KBMe
I have also realized something in a short time. I have started using Task
Manager to watch the CPU usage since there seems to be a severe shortage of
status indicators. If the CPU is still running high percentages, the
program is still working.
Clark
news:ekIqe.2622$751.587@newssvr30.news.prodigy.com...
> Clark
>> 1.3.0.195
>>> Clark
>> but
>>> > 'remove'
>>> > KBMe
Thanks, Clark.
I ended up hitting the delete key instead of the remove button in the
program.
Worked like a charm.
KB
news:hZJqe.3697$%j7.2277@newssvr11.news.prodigy.com...
of
> Clark
using
behavior
liked
finding
when.
is
It
> > Clark
> >> 1.3.0.195
> >>> Clark
jv16
> >> but
> >>> > 'remove'
> >>> > KBMe
