G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
I have K8NF-9 board and AMD64 3000+ CPU. I purchased 4 pcs 512 mb
PC3200 memory modules - Generic Memory. The system will only boot
with memory modules installed - the two can be in any DDR1 and 2 or
DDR 3 & 4. The memory being purchased all at one time, I thought
it would be compatible. Question is, is this a memory or M/Brd
problem?
Also notice that the bios lets me change the cpu setting between 200
and 400mhz. Is the FSB?, so would I be corret to change this to 400
if using PC3200 memory?
Been a while since I built a PC - things have changed, so any advice
appreciated!
Thanks
problem?
appreciated!
Thanks
