Tom's Hardware > Forum > Smartphones & PDAs > Windows Mobile > WiFi problem after ROM u/g
Forum Smartphones & PDAs : Windows Mobile - WiFi problem after ROM u/g
Archived from groups: microsoft.public.pocketpc,microsoft.public.pocketpc.wireless (More info?)
I have an Ipaq 4150 with PPC2003 and a 802.11b linksys WAP. I could connect
flawlessly to the Internet until I upgraded the IPAQ ROM to version 1.10
Now I cannot connect to my WAP at all, even though my laptop continues to
connect without a problem. I have tried the usual resets, switch on and off,
remove/add settings but to no avail.
Can anyone help?
Thanks.
Sponsored Links
I can't help - but I can commiserate! I had exactly the same issue.
Wireless connections were perfect before the upgrade, impossible
afterwards. I've gone back to the previous ROM, and everything is back to
normal again.
> Can anyone help?
> Thanks.
Reply to Anonymous
- 0 +
Reboot your wireless router and you should connect fine. I had the same
problems after 2 rom updates on 4150`s, spent hours trying to connect. I
rebooted the wireless router and everthing worked fine on the ppc.
TH
"ZB" <zb@hotmail.com> wrote in message news:2ok2hhFavlgoU1@uni-berlin.de...
> off,
> Can anyone help?
> Thanks.
Reply to TH
> same problems after 2 rom updates on 4150`s, spent hours trying to
> connect. I rebooted the wireless router and everthing worked fine on
> the ppc.
> TH
That was one of the first things I did and it still doesnt work :-(
Reply to Anonymous
Archived from groups: microsoft.public.pocketpc (More info?)
I've got exactly the same problem. Funny thing is it worked fine for a day.
Now Wi fi fo fum won't even detect a signal when I know for a fact that both
I and my neighbor have our access points on.
gg
connect
off,
> Can anyone help?
> Thanks.
Reply to Anonymous
Have you tried removing the battery and pressing the reset button 5 times?
You need to do that on a 5555.
David Hettel
Microsoft MVP Mobile Devices
This posting is provided "as is" with no warranties, and confers no rights.
You assume all risks for your use.
Handhelds, mobile: http://www.geekzone.co.nz
Bluetooth guides: http://www.geekzone.co.nz/content.asp?contentid=449
"ZB" <zb@hotmail.com> wrote in message news:2okhvaFbr9laU1@uni-berlin.de...
>> the ppc.
>> TH
Reply to Anonymous
I just removed the hp Ipaq h4x00 WLAN driver update and that seems to have
done the trick.
gg
"David Hettel MS MVP - Mobile Devices" <dhettel@fuse.net> wrote in message
news:%23Q6Q1dmhEHA.2784@TK2MSFTNGP09.phx.gbl...
> David Hettel
rights.
> >> the ppc.
> >> TH
Reply to Anonymous
> times? You need to do that on a 5555.
Do I just press the reset button with the battery out or should I do 5 soft
resets?
Reply to Anonymous
> connect flawlessly to the Internet until I upgraded the IPAQ ROM to
> version 1.10
> continues to connect without a problem. I have tried the usual
> resets, switch on and off, remove/add settings but to no avail.
> Can anyone help?
> Thanks.
Update, I have turned WEP encryption off and it works fine - obviously not
ideal though is it!
Reply to Anonymous
Your Wifi chanel ranges don't overlap do they ?
What happens if you select a different channel for the accesspoint ?
On Thu, 19 Aug 2004 19:00:51 -0700, "Garry Gelowitz" <garrcon@shaw.ca>
>gg
>connect
>off,
>> Can anyone help?
>> Thanks.
Reply to Anonymous
Check wifi settings, advanced, select networks, Edit...,
proxy settings, [x] This network connects to the hellhole
called the internet. (OK) Make sure the other Edit...
under network management has the same [x] checked, or
whatever works best. I recall these not being checked
after the rom upload. Something doesn't work right if
they're not. What, I don't know.
40th Floor - Software @ http://40th.com/
iPlay : the ultimate audio player for iPAQs
mp3, ogg, mp4, m4a, aac, wav, and then some
Reply to Anonymous
That would suggest that you are not entering the WEP key correctly to me.
Are you entering the HEX version of the key? And not the plain text? Also
the complete key needs to be entered on one line.
David Hettel
"ZB" <zb@hotmail.com> wrote in message news:2olqp5Fc5spkU1@uni-berlin.de...
>> version 1.10
>> Can anyone help?
>> Thanks.
> ideal though is it!
Reply to Anonymous
> me. Are you entering the HEX version of the key? And not the plain
> text? Also the complete key needs to be entered on one line.
I am indeed. It worked before, but refuses to work now.
Reply to Anonymous
> version 1.10
> Can anyone help?
> Thanks.
Tried all the suggestions made that I hadnt tried without success. Reported
the fault to HP, they'll investigate and get back to me sometime next week,
in the meantime I'm going to install an update for WLAN even though it isnt
supposed to do anything related to WEP and see if it makes a difference.
I'll post an update when I get one.
Reply to Anonymous
Hi,
I also experienced the same issue.
What I did: also removed the hp iPaq h4x00 WLAN driver.
And not to forget I introduced my WEP-key in UPPERCASE.
I introduced the key in lowercase and that's the reason why it didn't work.
The last thing to find out now, is connecting to the Internet.
At least I can already connect to my PC again.
Kind regards,
JL
"Garry Gelowitz" <garrcon@shaw.ca> wrote in message
news:ufXjYjmhEHA.1724@tk2msftngp13.phx.gbl...
> done the trick.
> gg
times?
> > David Hettel
> rights.
> > >> the ppc.
> > >> TH
Reply to Anonymous
Thanks, this appears to have fixed my problem. I am now back on line
with my home wlan and WEP is working fine.
Pat
wrote:
> *Check wifi settings, advanced, select networks, Edit...,
> mp3, ogg, mp4, m4a, aac, wav, and then some *
pcaulfi
Posted via http://www.mcse.ms
View this thread: http://hardware.mcse.ms/message63914.html
Reply to Anonymous
There are 1158 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
