Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
I have two hardrives: a Western Digital 80gig (windows is installed on
this one), and a Western Digital 160gig. I have 30gig partitioned on the
first one, and 100gig on the second. I run WinXP fully updated, but am
unable to create or resize a partition. I have tried creating a new
partition on both drives using the default windows utility, as well as
PartitionMagic 8.0 (also tried resizing with this)... neither works. The
windows utility says it couldn't be done and to check the system log and
reboot if necessary. PartitionMagic says either it is a write error or
can't be done. Any ideas? I'd like to be able to use that extra space.
Thanks a lot!
Eric
Thanks a lot!
Eric
