G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
To power up the computer, you must physically push the front power switch
(which, I think, is called a soft switch). The back power button, which is a
regular on/off switch, must be on - no problem there.
I need to have the computer power up by itself in case of a power shortage.
There is no setting in the Bios Setup that can be changed for that. The
subject was discussed here a few years ago, without result.
I thought of something. There are, I believe, 2 wires from the mobo to the
soft switch. I could short them, I mean cut them and solder them together.
1) Would that do the trick ?
2) Is there any other way ?
The setup:
Abit BH6 rev. 1.0
Pentium2 350 MHz
Chipset: Intel 440BX
Power switch: the "soft" type
Award Bios with the last update: SS
06/28/2000-i440BX-W83977-2A69KA1EC-SS
OS: irrelevant (Windows)
The setup:
Abit BH6 rev. 1.0
Pentium2 350 MHz
