Archived from groups: microsoft.public.windowsme.general (More info?)
Has anyone experienced problems after installing critical update KB903235?
After installing it I've discovered that system restore doesn't work. I
went through all my old checkpoints and system restore got half way through
the bar going across the screen, the computer rebooted and told me that I
can't restore to that checkpoint.
I ran scandisk which fixed errors. I didn't defrag. I then tried the SR
test of adding a shortcut to the desktop after creating a checkpoint and
system restore hung with the bar 1/4 of the way across the screen. I had to
ctl-alt-del and end task on system restore.
Is there a way to ininstall KB903235? What else can I do to get system
restore back up and running?
Nothing else on the system appears to be affected as all is functioning
properly.
Grasping at straws here.
Any guidance would be most greatly appreciated.
KB
properly.
KB
