Archived from groups: alt.comp.hardware.pc-homebuilt (
More info?)
larry moe 'n curly wrote:
>>>I remember looking inside another model in a store and
>>>wondering where the power transformer was because it was
>>>so small for a PSU of its watt rating. Maybe they run
>>>the transformer at a much higher than normal frequency,
>>>which would allow a smaller transformer, but I have a
>>>feeling they simply skimped on it.
>>>But $99 for that PSU? No way. Get a 450W or higher Antec
>>>TruePower, Zippy-Emacs, or Fortron-Source (Fortorn, Sparkle,
>>>Powerman, etc.) instead; it will probably be able to put out
>>>more actual power.
>>is it possible that its actually rated under a different
>>wattage other than 600 watt?
>>yeah, its seems awfully cheap for 600 watt.
> How do you rate a 600W with different watts? One of the worst
> companies, Q-tec, cheats on the power ratings and simply multiplies the
> amps x volts for each rail and adds the products,
It's worse than that. They rate the PSUs with "peak" watts, a useless term.
> but few ATX PSUs will
> have continuous power ratings equal to such a sum. The power rating is
> generally 10-30% lower.
