Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Hello Everyone. I'm a first-time poster here. I built my second PC
from scratch several years ago and it worked like a champ. Still is,
AFAIK.
So, I confidently set about re-plumbing my old Gateway G6-266. I have
an Intel D875PBZ main board, 3.0Ghz CPU, 1G RAM, misc drives, PCPower
Silencer ATX power supply, and an ATI All-In-Wonder VE video board.
The problem is that when I turn on the power supply, the CPU fan spins
up and the available power light comes on on the main board. Nothing
happens after that. I have tested the power and reset switches and am
confident that they work. I tried shorting the two startup pins
together with a test lead from my DMM. Then I bought a power supply
tester; it shows that the PS is working, except for the -5V line. The
drives and video card are from other machines, and were working when
they were pulled. The mainboard, CPU, and RAM are all new.
I've pulled and re-seated everything. I made sure that the board was
not shorting to the frame, and that the insulated washers are in place.
I don't think the CPU fan should come on, but it does.
Does anyone have any suggestions?
Thanks,
Mike
AFAIK.
Thanks,
Mike
