Archived from groups: alt.comp.hardware.pc-homebuilt (
More info?)
Dave E wrote:
> Yes,
> After reading online reviews for 54kbs varieties it seems that Netgear come
> out tops
I have a netgear g+ (2xg = 108mbps) router (WGT624) and it's quite nice.
Personally, I'd be looking at g+ routers, especially the Netgear ones
with the XR (extended range) feature. IIRC, there are even 4 x g
(216mbps) ones available from Netgear now.
Ari
> David
> "DCA" <dca860MAPS@yahoo.co.uk> wrote in message
> news:IAj0e.3744$d55.1812@newsfe5-gui.ntli.net...
>>"o-chan" <poda@REMOVEmac.com> wrote in message
>>news:d1s8st$16bm$1@netnews.upenn.edu...
>>>>OK - first some advice from you knowledgeable folk
>>>>If I want to buy a device that allows me to connect to tiscali broadband
>>>>in a different part of the house (without wires) - what do I need? A
>>>>wireless LAN to the supplied device or do I need to replace the lot with
>>>>some router? The PC is a desktop (not laptop)
>>>>Any advice and recommendation for devices gratefully received
>>>>Thanks
>>>>David
>>>You need a wireless router to connect to the cable/DSL modem. Then, on
>>>the desktop side, you need either: a PCI wireless card, or a USB wireless
>>>adapter, or a wireless access point (running in repeater mode) for your
>>>ethernet port.
>>>All 3 options can be about the same price. The access point option will
>>>probably provide you with the best signal and doesn't need drivers, but
>>>it adds another wire and needs to be plugged in.
>>Thank-you both
>>Any recommendations for makes?
spammage trappage: replace fishies_ with yahoo
I'm going to die rather sooner than I'd like. I tried to protect my
neighbours from crime, and became the victim of it. Complications in
hospital following this resulted in a serious illness. I now need a bone
marrow transplant. Many people around the world are waiting for a marrow
transplant, too. Please volunteer to be a marrow donor:
http://www.abmdr.org.au/
http://www.marrow.org/
