Archived from groups: alt.comp.hardware,alt.comp.hardware.pc-homebuilt (More info?)
Hello all,
I've recently had a serious HD crash using an external caddy via Firewire -
basically the disc cannot be read though the drive and partitions can be
seen by XP and I'm able to format the drive (if I wanted to). The drive is a
Maxtor 120GB and is over 2 years old - unfortunately it also
contained/contains my holiday photos and mp3 collection (it also failed the
night before I was finally going to get round to backing the drive up onto
DVD's!! (
Anyhow I put another drive in the enclosure (brand new Seagate 120 GB) but
just used it the internet cache this time to see if the above problem was
repeated - it was last night but this time I formatted the drive and now
using it (via the USB connection).
Have I got a faulty enclosure (my guess); a Firewire (USB would be
*better*?) or a common problem with external enclosures generally?
TIA
BillL
Sys spec/config
AMD A64 3200+ (Winchester)
Gigabyte GA-K8NXP-SLI (F6 BIOS)
1 GB RAM (2 x 512 MB Crucial Ballistix DIMM's) PC4000
Leadtek PX6600GT 'Extreme'
External USB Creative NX2 Sound
Coolermaster 'Wavemaster'Case
OCZ 'Powerstream' 520Watt PSU
DISCS
Maxtor DiamondMax 250 GB SATA150 (On nforce4 controller)
Seagate 120 GB PATA in external Firewire/USB 'ICY BOX' enclosure
Secondary IDE Channel
Samsung 16x DVD
NEC 3500A DVDRW
OtherHW
HP 940C USB Printer
Epson R300 Photo
Cannon LiDE30 USB Scanner
Hauppauge WinTV PCI
OS: WinXP Pro SP2
Hello all,
DVD's!! (
TIA
BillL
Sys spec/config
DISCS
Samsung 16x DVD
NEC 3500A DVDRW
OtherHW
HP 940C USB Printer
Epson R300 Photo
Hauppauge WinTV PCI
OS: WinXP Pro SP2
