Archived from groups: microsoft.public.windowsme.general (More info?)
I am trying to set up a home network involving two computers (one with
Windows Me and one with Windows XP) and a wireless router.
I have almost everything working. One the WinMe computer, I can see
and use files in shared folders on the WinXP computer, but not the
other way around. When the WinXP computer tries to access shared files
on the WinMe computer, it gives an error saying that it does not have
the right permissions.
What setting(s) on the WinMe computer do I need to change?
Paige Miller
pmiller5@rochester.rr.com
http://paiges-page.net
It's nothing until I call it -- Bill Klem, NL Umpire
If you get the choice to sit it out or dance,
I hope you dance -- Lee Ann Womack
Sponsored Links
> I have almost everything working. One the WinMe computer, I can see and
> use files in shared folders on the WinXP computer, but not the other way
> around. When the WinXP computer tries to access shared files on the
> WinMe computer, it gives an error saying that it does not have the right
> permissions.
Just a guess, try enabling the guest account on the XP box
Jim
Reply to Anonymous
- 0 +
If you haven't done so, create a user on your XP machine that is the
same as the user log on for your ME machine. It's not necessary to be
logged on to the XP machine with the same log on, only that the user
exists on the XP box. If you're using a software firewall such as
Zonealarm, insure that the IP addresses for each machine are set as
trusted in ZA, or set a range of addresses as trusted on each. If your
router has a firewall capability and it's enabled, it may also be
necessary to create a firewall rule to permit access. Lastly, you'll
need to share a resource on the ME machine.
The Guest account on XP needs to be enabled for XP to see ME, so it
appears that you're okay with that.
> permissions.
Reply to TomV
Tom's Hardware > Forum > Windows 95/98/ME > Windows 95/98/Me General Discussion > Home Networking Problem
There are 499 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 sighQ2 won the Freshman badge
  • 09:06 ulysses35 won the CPUs badge
  • 01:00 fleeb won the Freshman badge
  • 01:00 jaymoney61 won the Freshman badge
  • 07:06 amdfangirl won the Watchman badge
  • 01:00 benw won the Freshman badge
  • 01:00 anmjoven won the Freshman badge
  • 01:00 dpnaugle won the Freshman badge
  • 01:00 ayeohx won the Freshman badge
  • 03:58 sanchz won the Sophmore badge
