Archived from groups: alt.comp.hardware.pc-homebuilt (
More info?)
ok first obviously my spell checker went wacky...SUB= USB
W
"DCA" <dca860MAPS@yahoo.co.uk> wrote in message
news:Asp7e.800$WP4.609@newsfe6-gui.ntli.net...
> "JAD" <kapasitor@earthcharter.net> wrote in message
> news
5W5e.115$_63.80@fe03.lga...
>> when you remove the pen drive do you use the SUB terminator (icon in the
>> task bar)?
Usually when things are loading properly, the icon for hotswap USB appears
in the task bar by the clock. (green arrow over a USB connector(my
interpratatoin as its pretty small). The only things I have seen that don't
have this are some scanners, but I suppose it could be for some USB storage
devices, but i doubt it.
> No - I don't but wasn't aware there was one! Kingston 512Mb
>> does your SUB drive have its own software (e.g. creatives nomadware)?
> Nope - XP
This CAN;;; work but some storage drives have a driver at least, because of
odd formatting...but then there should be software that formats it, if its
not conventional.
>> here's a couple of things you can try:
>> in the bios there are settings for USB legacy devices-try different
>> settings.
> There are no settings - Dells own limited BIOS
I was afraid of that...
>> have a copy of windows explorer open in the background while trying the
>> same
>> tasks as you described.
> Already tried as I was trying to drag from CD to USB when it first locked
> up
It seems that it has some kind of driver because of its format.
what about the manufacturers web site?
>> news:_NV5e.18845$pA6.11249@newsfe1-win.ntli.net...
>>> I have a Dell Dimension 8300. Very happy generally BUT, when I try to
>>> load
>> a
>>> CD when I have a 'pen-drive' or MP3 ce ited in the US port, it freezes
>>> up
>>> completely.
>>> When the sB drive is removed I can rip the CD and then AFTER removing
>>> the
>>> Ccan insert and transfer the MP3 file
>>> I would g at a lash of interrupts - but I thought these crashes were a
>> thing
>>> of the past with Win XP?
>>> Any ideas or help appreciated as this is bloody annoying as a re-boot is
>> the
>>> only remedy
>>> David
