G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Hi,
I just bought the Asus A7N8X-X motherboard and 512MB PC3200 ram..but
when I set everything up and start the system, I end up getting a
bluescreen with white writing then the computer reboots.
I also notice that my cpu is running at 1.1ghz when I start the
computer...anyone know why that is :?:
:arrow: My specs are listed below:
AMD Athlon Xp 1800+ (1.53ghz)
Asus A7N8X-X
512MB PC3200 DDR400
20GB HDD
40GB HDD
Leadtek Winfast A280 LE TDH MyVIVO (128MB, 8X AGP)
Sound Blaster Live Value (sound)
400W PSU
10/100 network
:idea: I also have Windows Xp Pro installed on the 20GB HDD (which I
read that it could be the cause..installation on different
Motherboard).
:arrow: It was installed when I was using my other computer which had
the Asus A7V333 motherboard.
If anyone can help, it'll be great.
Thanx
Hi,
Asus A7N8X-X
512MB PC3200 DDR400
20GB HDD
40GB HDD
400W PSU
10/100 network
Motherboard).
Thanx
