Hard drive bad sectors, help?
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Hi,
I have had my Seagate 160GB drive (as recommend on here I believe) for only
a few weeks now and it's reporting bad sectors (in Event Viewer and using
the tools on the cd that came with it).
However, the bad sectors are not always in the same place, as sometimes I
can't copy certain files due to bad sectors and the copy fails, but other
times the copying is fine.
Is this normal behaviour for bad sectors? I would have thought that if
there was a bad sector, then I would never be able to copy the file.
It's also always only one partition (out of three). I'm thinking of just
formatting this partition and copying everything back on again.
Or should I just send it back?
Thanks,
Grendel.
4 answers Last reply
More about hard drive sectors help
  1. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    > believe) for only a few weeks now and it's reporting bad sectors
    > (in Event Viewer and using the tools on the cd that came with
    > it).
    Bad sectors are usually very bad. Hopefully you have a copy of any
    important data on another disk or on removable media.
    If you are really talking about bad sectors, that sounds very very
    bad.
    If you want more critical opinions, the best group for hard disk
    drives is probably this one.
    comp.sys.ibm.pc.hardware.storage
    Good luck.
    > as
    > sometimes I can't copy certain files due to bad sectors and the
    > copy fails, but other times the copying is fine.
    > that if there was a bad sector, then I would never be able to
    > copy the file.
    > thinking of just formatting this partition and copying
    > Thanks,
    > Grendel.
  2. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Grendel wrote:
    > Hi,
    > Thanks,
    > Grendel.
    Download the seagate seatools program for putting on either a floppy or
    burning to a cdrom. Make the disc. Put it in the drive. Restart your
    computer and see what the full diagnostic testing reports. If you have
    bad sectors, you need to return the drive for a replacement.
    spammage trappage: replace fishies_ with yahoo
    I'm going to die rather sooner than I'd like. I tried to protect my
    neighbours from crime, and became the victim of it. Complications in
    hospital following this resulted in a serious illness. I now need a bone
    marrow transplant. Many people around the world are waiting for a marrow
    transplant, too. Please volunteer to be a marrow donor:
    http://www.abmdr.org.au/
    http://www.marrow.org/
  3. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    >computer and see what the full diagnostic testing reports. If you have bad
    From my perspective you couldn't get any better advice.
    Jan Alter
    bearpuf@verizon.net
    or
    jalter@phila.k12.pa.us
    "spodosaurus" <spodosaurus@_yahoo_.com> wrote in message
    news:4263bbc9$1@quokka.wn.com.au...
    > Grendel wrote:
    >> Hi,
    >> only a few weeks now and it's reporting bad sectors (in Event Viewer and
    >> using the tools on the cd that came with it).
    >> Thanks,
    >> Grendel.
  4. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    "John Doe" <jdoe@usenet.love.invalid> wrote in message
    news:Xns963CA2A59BCBFwisdomfolly@207.115.63.158...
    Thanks for all the replies. I couldn't create a bootable floppy cos I
    haven't used the floppy drive for so long that it's sat on the loft
    somewhere.
    I did however boot from the cd, which reported *lots* of bad sectors.
    I have requested an RMA, so it looks like it'll have to go back (after I try
    to copy off what I need and wipe it clean).
    Thanks,
    Grendel.
Homebuilt Hard Drives Systems
