G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Hi,
I just changed my processor upgrading from 2.53ghz to 3.2Eghz.
and my power supply of 350W, actually the fuse, was blown!
We hear a big noise and lights out of the fan. Seems like NOS in need
for speed. lol
my specs are:
MSI PT880 Neo-LSR
2x512MB Dual Channel PC 3200 KingMax
ATI ALL IN WONDER X800XT
4 Hard Drives:
• 1 SATA MAXTOR 300GB
• 1 IDE WESTERN DIGITAL 80GB
• 1 IDE Maxtor 20GB
• 1 IDE Seagate 8GB
• 1 IDE Seagate 200GB
1 DVD Burner Pioneer DVR-109
1 2005FPW DELL 20.1" LCD
1 Z5500 5.1 Surround Sound.
I first had 2 power supply.
1 connected to the motherboard + Graphic Card.
The other 1 connected to all the drives.
Both power supplies are 350W each.
Then I was running 3dMark05, and 1 power supply blow, you can hear a
*Boom* with lightss.
Then I took that one out, and now only 1 Power Supply which is
connected to all of the drives + mobo + graphic card.
the starting screen of the BIOS was slower than before, and I was
checking my emails and I had the PC turn on for about $15 minutes,
the Other power supply blowed!!
2 Power supplies down. and I don't know if it's the CPU, because
that's the only change I did.
Before with the 2.53Ghz, it worked just fine with all the specs.
I then opened the power supply to see what's wrong with it.
I found out that the fuse of the power supply blowed for both of the
power supplies.
Does anyone has the solution to this, or did anyone had the same
problem?
Should I buy a surge protector, a more powerful power supply or
anyting that would make my system work again?
Thank you in advance,
Hi,
for speed. lol
my specs are:
MSI PT880 Neo-LSR
4 Hard Drives:
• 1 IDE Maxtor 20GB
• 1 IDE Seagate 8GB
power supplies.
problem?
