G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
I just bought the Gigabyte GA-K8NS Ultra-939 along with an Athlon 64
3200+ in a retail box (standard AMD fan). When I hooked everything up,
the CPU fan stopped running while I was setting up the inital bios
settings. The CPU fan fail alarm immediately went off. I then turned
the smart fan control off to avoid frying my CPU and everything appears
to work. My question is according to the manual (yes I did read it) the
fan speed is reduced if the temperature is lower then 40 c. I assume
reduce means it is still running not stopped. Is this normal? Needless
to say, I didn't wait for the cpu to haet up to see if it start running
again. Other than that, the board seems fine. I would still like to use
this feature if it actually works.
