CPU/System temp questions
Last response: in Systems
Anonymous
Homebuilt system Expert
CPUs Authority
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Howdy: I have an Athlon 1800 XP with a DFI AM75-TC motherboard. With
the motherboard driver CD is a VIA hardware monitor. It has the CPU
overheat temp and system overheat temp set at 50 degrees celsius. The
CPU right now is running at 44 degrees and the system is at 36
degrees. Is this normal? And what should I safely set the max
overheat temp to?
And what the hell is CPU/System Hysteresis temperatures???? And what
should they be set at?? Would appriciate any info, thank you.
The Seabat
Anonymous
CPUs Authority
On Fri, 22 Apr 2005 23:27:30 -0500 If I have seen farther it is
because I have stood on the shoulder of giants The Seabat
>overheat temp to?
55 Deg C but don't worry as you are well within the 90 Deg C max for
the CPU :)
See other thread on,"Hysteresis ".
Free Windows/PC help,
http://www.geocities.com/sheppola/trouble.html
remove obvious to reply
email pds@OBVIOUSpartybombe.de
Free original songs to download and,"BURN" :o )
http://www.soundclick.com/bands/8/nomessiahsmusic.htm
Ask the community
