G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
I recently upgraded my system to use an ASUS K8V SE Deluxe, in a
fairly generic case that has no built-in capability for front-panel
audio. The only thing I've seen so far for adding that capability to
a case like this seems to be the ASUS iPanel Deluxe, but a) it does a
lot more than I want, b) it costs more than I want (and I don't like
paying for functionality I don't need), and c) I haven't even found a
place that sells it, although maybe I could get one through eBay or
some such site.
All I *really* want is a way to connect a microphone, without
disconnecting my speakers. I wish I'd thought of that before I
selected this motherboard, since the only way to do that is using the
FP_AUDIO interface which currently is useless to me!
Any ideas for a way to get a mic input installed? It doesn't have to
be pretty, it just has to work without causing other problems.
S. Whitmore :: usenet-bounce@just-stuart.com w/o -bounce
http://www.just-stuart.com/
http://weeklypixmuse.blogspot.com/
some such site.
