G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Hi folks,
Not sure if this is the right group for this question but from experience
this group seems to have the smartest people on it.
I have a homebuilt Asus A7N-based Win2K system. I just installed a firewire
card so I could capture movies from my mini DV cam. The card came with
Ulead VideoStudio 5.0 software which I set up and got running. I captured a
couple short test clips which worked out fine. I thought I was ready to
roll so I then tried a capture of a full hour-long tape. The default
storage folder for captured video was on the C: drive so I reassigned it for
my D: drive which is a physically separate Seagate 200 gb hd. During the
capture the program froze although I could still see the clock moving.
After the tape was done I got errors that my D: drive was unreadable. After
a restart I got new errors saying that the drive isn't formatted and asked
if I wanted to do it then - which I didn't do since I have lots of data on
there that I'd like to save. Any idea what I should do next?
Thanks a bunch,
Nate
Hi folks,
Thanks a bunch,
Nate
