Need help, please, clearing CMOS
Last response: in Systems
Anonymous
a b B Homebuilt system
May 10, 2005 12:57:11 PM
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
In upgrading an Intel D815EEA to a 1.2 Tualatin, using Upgradeware's
adaptor, it was suggested that I clear the CMOS and use BIOS P10. Well, I
did install P10 (from P11, so that was 'downgraded'), can someone please
guide me in doing this. I could use some help since any mistakes might turn
out disastrous... thank you!
B'Regards,
Vinnie
More about : clearing cmos
Anonymous
May 10, 2005 5:51:46 PM
Hi Vinjust google for D815EEA, it`ll take you to the Intel site, all the
info is there. best wishes..J
"Uncle Vinnie" <vinrin57@nospam.optonline.net> wrote in message
news:p c2ge.173$NZ1.98@fe09.lga...
> turn out disastrous... thank you!
> B'Regards,
> Vinnie
Anonymous
May 10, 2005 5:51:47 PM
Thank Jon! Yes, I have looked, but found it to be a little over my head, so
before I mess things up, I hoped someone here who has done this before,
might be willing to explain the steps better than what I've found on their
site... I will double check, it is possible I missed something already
there...
Thanks again...
"old jon" <jonbrookes@nospamntlworld.com> wrote in message
news:S%2ge.1099$V%.540@newsfe1-gui.ntli.net...
>> I did install P10 (from P11, so that was 'downgraded'), can someone
>> please guide me in doing this. I could use some help since any mistakes
>> might turn out disastrous... thank you!
>> B'Regards,
>> Vinnie
Anonymous
May 10, 2005 7:32:06 PM
Hi Vin, don`t know the actual machine but a standard way of clearing CMOS is
to open computer, and remove the small, round silver battery for a while,
this will reset the bios to standard, but you will then have to go into the
bios on restart to tweak any settings that need it. It`s not difficult. ..J
> B'Regards,
> Vinnie
Anonymous
May 10, 2005 7:32:07 PM
Thanks Jon... If I do that, do you know if the previous BIOS (P10) will
still be there?
news:Wt4ge.594$Nt.129@newsfe4-gui.ntli.net...
> is to open computer, and remove the small, round silver battery for a
> while, this will reset the bios to standard, but you will then have to go
> into the bios on restart to tweak any settings that need it. It`s not
> difficult. ..J
>> B'Regards,
>> Vinnie
Anonymous
May 10, 2005 8:01:20 PM
Yes it will, but why you had to downgrade the bios puzzles me..J
news:QD4ge.396$HJ2.230@fe11.lga...
> still be there?
>> difficult. ..J
>>> B'Regards,
>>> Vinnie
Anonymous
May 10, 2005 8:01:21 PM
The last version, P11, would not recognize anything over 933mhz, P10 would.
This adapter is similar to Powerleaps which would enable one to use a 1.2
Tualatin in a 370 socket.
news:kV4ge.1111$V%.497@newsfe1-gui.ntli.net...
>> still be there?
>>> CMOS is to open computer, and remove the small, round silver battery for
>>> a while, this will reset the bios to standard, but you will then have to
>>> go into the bios on restart to tweak any settings that need it. It`s not
>>> difficult. ..J
>>>> Well, I did install P10 (from P11, so that was 'downgraded'), can
>>>> someone please guide me in doing this. I could use some help since any
>>>> mistakes might turn out disastrous... thank you!
>>>> B'Regards,
>>>> Vinnie
Anonymous
May 11, 2005 3:07:03 AM
On Tue, 10 May 2005 08:57:11 -0400 If I have seen farther it is
because I have stood on the shoulder of giants "Uncle Vinnie"
If you have the user manual for the mother board it will show where
the,"Clear CMOS"jumper is.Isolate the PC from it's power
supply(Required to fully discharge BIOS on ATX powered systems) by
using the power supply isolator switch if there or removing the power
cord.
Use the Clear CMOS jumper.Re-apply power.
It may be worth your while taking the time to write down your present
BIOS settings.
HTH :)
Free Windows/PC help,
http://www.geocities.com/sheppola/trouble.html
remove obvious to reply
email pds@OBVIOUSpartybombe.de
Free original songs to download and,"BURN" :o )
http://www.soundclick.com/bands/8/nomessiahsmusic.htm
Anonymous
May 11, 2005 7:18:29 PM
Thanks Jon / Shep...
Worked fine..! CPU Recognized.....all else left 'automatic'!
news:j45ge.400$HJ2.45@fe11.lga...
> would. This adapter is similar to Powerleaps which would enable one to use
> a 1.2 Tualatin in a 370 socket.
>>> still be there?
>>>> for a while, this will reset the bios to standard, but you will then
>>>> have to go into the bios on restart to tweak any settings that need it.
>>>>> any mistakes might turn out disastrous... thank you!
>>>>> B'Regards,
>>>>> Vinnie
Anonymous
May 11, 2005 11:21:22 PM
Very pleased, glad we could help. best wishes..J
news:kUsge.1158$NZ1.819@fe09.lga...
>> use a 1.2 Tualatin in a 370 socket.
>>>> still be there?
>>>>>> B'Regards,
>>>>>> Vinnie
Anonymous
May 12, 2005 1:09:34 AM
On Wed, 11 May 2005 19:21:22 GMT If I have seen farther it is because
I have stood on the shoulder of giants "old jon"
Ditto :)
>>>>> still be there?
>>>>>>> B'Regards,
>>>>>>> Vinnie
