Very low power PC?
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Id like to give a try at building my own PC
However.... I'm wanting something very low power
consumption as I intend to leave the PC on 24/7.
Is it even possible to have a low power desktop PC?
Not much utility in a PC that one has to turn off/on
whenever needing to use it at home.... in my opinion.
Also... may want to leave it on 24/7 to act as a PVR
21 answers Last reply
More about very power
  1. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Get a Via C3 machine. I got a barebones shuttle system with a 1GHz
    Nehemiah processor onboard. It has built in sound, graphics, LAN,
    firewire, and USB. It's in a small Ali case, which looks amazing, and
    was £130 from overclockersUK. Just had a look though, and they seem
    to have stopped doing it.
    The 1GHz CPU I had has a max power consumption of about 18W, whereas
    other modern processors are all over 50W. They do some slower
    processors which are even cooler though, and you can get them in the
    mini-itx (very small) form factor. Some of these are now available on
    ebuyer, but are relatively expensive becaue of their size.
    The performance of these CPUs isn't like Athlons or Pentiums, but I
    haven't found much difference between my 1GHz C3, and my Athlon XP
    1700+. The FPU is supposed to be rubbish, and it does seem to take a
    long time for compression and decompression (such as zip files). The
    other cores (non-Nehemiah) have a half speed FPU which makes them even
    worse. I've added a PCI Geforce 4 MX440 to my C3 machine, and it can
    play Counterstrike at a high resolution with no problems. In fact it
    matched my Athlon XP 1700+ with a similar graphics car, but with the
    APG verion. For some strange reason the CPU usage seems to be
    approxamately half on the C3, than the XP. It's only at 22% while
    running Counterstrike, so Counterstrike obviously isn't CPU intensive.
    I'm not sure what a PVR is. These kind of machines would be ideal for
    something like a file server though. There's loads of mini-itx stuff
    available at mini-itx.com
  2. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    I recently did a power-consumption test on a P-II-300mhz
    and found that in idle it only drew 50 watts!
    Under full cpu load it was perhaps 100 or so
  3. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Probably not if you want to use it for serious gaming.
    Integrated components such as sound, video, and modem/LAN probably
    are lower power. They are usually lower performance too.
    Leave it on except turn it off at night? Use a CPU idling program?
    Try power management?
  4. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    yreah I know I can do all that
    but was curious if there are some low power
    components... CPU, etc.... one can use to "design in"
    low power efficiency
  5. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Of course that really depends on the details of your usage.
    I forgot to mention windows XP includes something called
    "hibernation". You probably are not always connected to the
    Internet, like an Internet instant messaging program, so you could
    use that I suppose.
    If I were you, I might tailor my search towards achieving that end.
    It is a challenge, others might have better advice (maybe in other
    groups too), I gave up using power management or anything like
    hibernation a long time ago (except for the monitor and hard disk
    drive). You will definitely want to use the most recent operating
    system.
    Seems to me that otherwise you would go with a notebook PC.
    Good luck.
    sorry for the additional reply
  6. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    yeah that may be a better option really
  7. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    >drive)
    Curious as to why you gave it up?
    Too much hassle to setup? Didn't work as expected?
  8. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    It will be spendy and choices of MBD are limited, but you can build a
    Pentium-M based desktop.
    <me@privacy.net> wrote in message
    news:v1ur811q7no1gbi0bc8fj1qd1ksp4b0efr@4ax.com...
  9. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    >>drive)
    Did not work as expected. Seems to me that Microsoft has had a
    difficult time coordinating its operating system efforts with
    mainboard maker's efforts. Others may have other experiences.
    Over time the technology becomes more efficient for the same speed,
    but still the higher the power the faster the system (and vice
    versa).
    If you don't like waiting for Windows to boot, see if hibernation
    will work. I would be interested to know whether it works for you.
    Maybe you can test it on your current system. Whatever, please let
    us know how it goes.
    Good luck.
  10. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    "Tweek" <shawnwingetNOSPAM@hotmail.com> wrote in message
    news:MPoje.34$yO1.13@trnddc05...
    An adaptor just came out that allows the Pentium-M to be used in Socket 478
    motherboards.
    http://theinquirer.net/?article=22948
  11. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    In article <Xns965C6C5F54567wisdomfolly@64.164.98.6>, John Doe says...
    THings have changed. Companies are now making motherboards which allow
    you to use a Pentium M.
    Conor
    "Of all the things I've lost, I miss my mind the most." O.Osbourne.
  12. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    In article <Xns965C88B958CEBwisdomfolly@64.164.98.29>, John Doe says...
    It isn't Microsoft that has the issues, its the hardware driver
    writers.
    Conor
  13. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    In article <u05s8112it06tle3grgt9h5avlm5mvkmdv@4ax.com>, says...
    Absolutely. Use mobile CPUs. Use slower CPUs. Use RAM instead of a HDD.
    Conor
  14. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    In article <AIrje.798388$w62.292217@bgtnsc05-
    news.ops.worldnet.att.net>, says...
    > motherboards.
    And there's even dedicated Pentium-M mobos now appearing.
    Conor
  15. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    John Doe <jdoe@usenet.love.invalid> wrote in
    news:Xns965C88B958CEBwisdomfolly@64.164.98.29:
    >>>drive)
    I also have had problems with hibernation and standby modes in Windows. The
    difficulties that I experienced were mostly related to Internet
    connectivity after the PC came out of those modes. A reboot was needed to
    solve the problem.
  16. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    True, but it only works with three ASUS boards.
    "dawg" <don't look@worldnet.att.net> wrote in message
    news:AIrje.798388$w62.292217@bgtnsc05-news.ops.worldnet.att.net...
    > 478
    > motherboards.
  17. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Is that the power of the whole computer? A PII-300MHz is probably less
    than 20W max.
  18. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    HDD.
    The Althon mobile XP's have a very low power rating, and are unlocked
    so can be underclocked to be even cooler.
  19. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    like mine down mentioned @ 1,35GHz
    impossible, mine does 65W ...
    Regards , SPAJKY ®
    mail addr. @ my site @ http://www.spajky.vze.com
    3rd Ann.: - "Tualatin OC-ed / BX-Slot1 / inaudible setup!"
  20. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Stands for "personal video recorder"
    Basically using your PC as a high tech VCR
  21. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Try using a highly efficient desktop power supply:
    - 80% or greater efficiency at 20%, 50% and 100% of rated load.
    - True power factor of 0.9 or greater.
    There’s a list of suppliers at www.80plus.org.
    Posted using the http://www.hardwareforumz.com interface, at author's request
    Articles individually checked for conformance to usenet standards
    Topic URL: http://www.hardwareforumz.com/Home-Built-low-power-PC-ftopict56169.html
    Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.hardwareforumz.com/eform.php?p=287024
Homebuilt Power Systems
