Label Printing for Jewellery Products
Last response: in Computer Peripherals
Archived from groups: comp.periphs.printers (More info?)
Hi,
I am looking for a label product for an Inkjet printer that will enable me
to print very small text onto a label that can be used to mark up Jewellery
(such as rings). Ideally the label should be able to hold a small barcode as
well and only touch minimal surface space of the jewellery (i.e. "hang off"
the small of the ring).
I know specialist printers exist for this purpose but they are expensive and
clumsy. It would be nice to find a product that can be used with standard
Inkjet printers.
Does anyone know of such a label product. Have taken a look through Avery's
catalogue but nothing seems to spring out as suitable.
Regards,
Richard Tubb.
"Richard Tubb" <richard@netlinktrading.co.uk> wrote in message
news:1z86d.3$OT1.2@text.news.blueyonder.co.uk...
> Hi,
This site _seems_ to have what you want....
http://www.rippedsheets.com/apps/ot/ring.html
BUT I think they are a company that will make ANY size blank label to custom
order... I found they have this page on their web site which looks like it's
designed to attract search engines rather than a real list of available
products. Perhaps I'm just a suspicious old sod.
http://www.rippedsheets.com/apps/ot.html
I've never used them myself so no idea on quality/reliability/delivery. Try
a small value order first?
The suggestion for RippedSheets is a good one. However, be very
cautious when printing very small barcodes with an inkjet printer.
The ink tends to spread just a little, affecting the width of the
narrow spaces; if the barcode is very dense, this can make things
difficult or impossible for the scanner. I would try printing some
test barcodes at the target size on plain paper before purchasing
special labels.
The problem of width errors in small barcodes can be especially acute
if you are using TrueType fonts to create Code 128 barcodes. Here is
a link to a technical article on that subject:
http://www.makebarcode.com/info/appnote/app_009.html
Bob Lounsbury
The Barcode Software Center
www.makebarcode.com
"Richard Tubb" <richard@netlinktrading.co.uk> wrote in message news:<1z86d.3$OT1.2@text.news.blueyonder.co.uk>...
> Hi,
> Inkjet printers.
> Regards,
> Richard Tubb.
On Tue, 28 Sep 2004 07:39:41 GMT, "Richard Tubb"
<richard@netlinktrading.co.uk> uttered:
Did you look at the 35mm slide label?
Dewi,
(remove spin for email)
Related ressources
Hi Dewi,
Thanks for the suggestion. I've done a thorough search of the Avery website
(www.avery.com) but couldn't find the 35mm slide label. Can you provide a
URL for me to take a closer look at this option?
Regards,
Richard Tubb.
www.netlinktrading.co.uk
"Dewi" <ngs@spin.wynwilliams.spin.freeserve.co.uk> wrote in message
news:o jrll01sp81p6o87afu46gspa9p9dsm423@4ax.com...
>>Avery's
> Dewi,
Bob & CWatters, thanks for the info on www.rippedsheet.com and barcode
printing - it seems worth placing a small order with rippedsheets to see how
I get on.
My client is actually based in the United Kingdom, but I don't know of
anybody here in the UK who provides a service such as rippedsheets. Would be
interested to hear if anyone knows of one.
Thanks again both, will let you know how I get on.
Regards,
Richard Tubb.
"Bob Lounsbury" <rhl@makebarcode.com> wrote in message
news:D 0a0311b.0409290543.37672f9d@posting.google.com...
> special labels.
> Bob Lounsbury
> www.makebarcode.com
>> Hi,
>> me
>> Jewellery
>> as
>> off"
>> and
>> Inkjet printers.
>> Avery's
>> Regards,
>> Richard Tubb.
On Mon, 04 Oct 2004 20:52:10 GMT, "Richard Tubb"
>Hi Dewi,
>Regards,
>Richard Tubb.
no URL, but the label number is L7656, 84 to a sheet
Dewi,
news:vSi8d.2643$xb.2264@text.news.blueyonder.co.uk...
how
> I get on.
be
There are lots of companies that do custom labels but there will usually be
a tooling up charge or you need to order large quantities.
Example
http://www.custom-labels.co.uk/main.htm
Ask the community
