Archived from groups: alt.comp.hardware.pc-homebuilt (
More info?)
well at one time , when 500w supplies were hard to come by or expensive,
people used a dual setup by using one for the 12v 5v for peripherals and the
other for the mainboard and its needs. There are more cons to using dual
PSU's than there are pros IMO. I suggest either relying on the higher/better
quality/newer one you have or break out 50 bucks for a 400-500w. brand name.
If you want to go with two, a google of 'dual/2 power supplies in one case'
will get you info.
"bob" <bob@localhost.localdomain> wrote in message
news
an.2005.05.28.18.20.22.187491@localhost.localdomain...
> On Sat, 28 May 2005 11:01:17 -0700, JAD wrote:
> > Been done,....for what reason?
> Mainly for future expansion. The case has been lying dormant for about a
> year. I got a really good deal on a AMD64 3700 and a Gigabyte K8NS Pro
> that will be going into this case.
