ABIT IS7E NorthBridge problem - Please help!
G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Hi,
My northbridge fan on IS7e doesn't work from some odd reason.
Has anyone exprienced such a problem?
Asaf
fisher
263
On Sat, 11 Jun 2005 20:59:09 +0200, "Asaf Mesika" <m_asaf@spymac.com>
wrote:
>Hi,
>Asaf
Another victim succumbs to the dreaded Abit nb fan issue. Go to the
Abit motherboard group, towards the bottom you will see a thread all
about Abit mb's and the nb fans, there are a few solutions there that
you can look into.
G
Guest
Guest
Had the same problem with an Epox motherboard. The chipset fan just seized.
You could try removing the paper label and putting a drop of machine oil in
there. There's a small hole just for that. Or just replace it.
"Asaf Mesika" <m_asaf@spymac.com> wrote in message
news:42ab2673$1@news.bezeqint.net...
> Hi,
> Asaf
G
Guest
Guest
Asaf Mesika wrote:
> Hi,
> Asaf
Either the fan is dead or the fan header is dead. If applicable, I'd
suggest switching to a zalman northbridge heatsink. I've done just that
with my Gigabyte GA-7VA board with no issues (except less fan noise!) :)
Ari
spammage trappage: replace fishies_ with yahoo
I'm going to die rather sooner than I'd like. I tried to protect my
neighbours from crime, and became the victim of it. Complications in
hospital following this resulted in a serious illness. I now need a bone
marrow transplant. Many people around the world are waiting for a marrow
transplant, too. Please volunteer to be a marrow donor:
http://www.abmdr.org.au/
http://www.marrow.org/
