G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Hi all,
I'm planning on setting up a linux software raid system, but first I
have to find a way to get all five of my IDE hard disks running on the
same system. I have an Abit HA66 IDE card (Highpoint HPT366 chip). When
I insert this card into the Asus A7V400-MX-SE board in my linux system,
the system will POST, then the HA66 will flash up it's 'hit ctrl-H to
configure' screen, then a black screen with a flashing underscore cursor
and that's it. It does the same thing with or without drives attached.
I put it into my WinXP Home system with a Gigabyte GA-7VA board and it
worked. I even installed the drivers successfully and attached my cdrom
to it as well as flashing it to the 1.28 BIOS. HOWEVER, if I attached
the boot hard drive to it, the results would be identical to what
happens with the Asus board in my linux system: black screen with
flashing cursor.
Does anyone have any idea what's going on here and how I can remedy this?
TIA,
Ari
spammage trappage: replace fishies_ with yahoo
I'm going to die rather sooner than I'd like. I tried to protect my
neighbours from crime, and became the victim of it. Complications in
hospital following this resulted in a serious illness. I now need a bone
marrow transplant. Many people around the world are waiting for a marrow
transplant, too. Please volunteer to be a marrow donor:
http://www.abmdr.org.au/
http://www.marrow.org/
Hi all,
flashing cursor.
TIA,
Ari
