G
Guest
Guest
Archived from groups: microsoft.public.windowsnt.domain (More info?)
Hello to all.
This is my first post here, so if I make any mistakes, my apologies.
I’m having serious problems trying to connect 2 domains, linked by a link with 2 routers (domains are in different locations). I’m trying to establish Trusts between them so that domain B users can access files in domain B, but so far all I can do is establish “Trusting�; it is impossible to establish “Trusted�.
In domain A, I managed to mark B as Trusting
In domain B, I managed to mark A as Trusting
But, when I try to add either as “Trusted� all I get is “Domain cannot be found�. The weirdest part is that, in the PDC of domain A, I can access and use shares from domain B (but not the reverse). Also, I can ping either PDC when using PDC (ping PDC A from PDC B and PDC B from A) but not workstations.
Any ideas on what might be the problem? Can the routers be responsible? Am I missing some service/option/config?
ANY help appreciated
Hello to all.
