G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
I've got an older P4 1.7 GHz machine. Recently, I've been having some
trouble, where the machine just locks up. Can't move the mouse,
keyboard won't work, the off-switch won't turn the computer off.
Totally unresponsive. The only thing that works is to hold the power
switch down for 5 seconds to do a hard shutdown.
The lock-up is semi-predictable. It seems to happen after about 5-15
minutes of heavy CPU activity. Most recently, it died several times
trying to transcode some slideshows into NTSC video using Nero, Roxio
and Picasa (so it's not software-specific). It has also behaved like
this when doing full system scans using Norton AntiVirus.
Most mornings, I can turn the monitor on to find the system in this
state. This probably due to the fact that my spyware and virus scans
try to run overnight.
I installed SpeedFan during my tasks to try and see if the CPU is
overheating (since heavy CPU activity causes the issue), but the
motherboard does not seem to be reporting on CPU temperature; probably
too old.
Any pointers on diagnosing the problem?
too old.
