Front USB ports don't work (Chenming case)
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
Yeah, it's another typical case where the two front USB ports from the case
have a 2x5 block connecter rather than individual pins, and of course the
wiring for the connector does not match the pinout on my motherboard (an
Asus A8V Deluxe). I can easily rearrange the pins in the block to match the
motherboard pinout, but unfortunately the case didn't come with docs and I
can't find anything online. The wires are all goofy colors, too (yellow,
purple, etc., rather that the standard red, white, green and black), so I
can't even get any clues from the wire colors.
If you have a Chenming case and have figured out the front USB wiring, I'd
certainly like to hear from you. Presumably, the Firewire connector wiring
is also wrong, but I sure don't want to plug a Firewire device in to find
out. <sigh>
5 answers Last reply
More about front ports work chenming case
  1. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    "Hackworth" <NoSpam4Me@spamless.net> wrote in message
    news:M8idnfmCjMnCwlnfRVn-3A@comcast.com...
    case
    the
    > out. <sigh>
    Which case model please.
    Richard
    http://www.vfaq.com/Case/#USB
  2. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    http://www.starmount.co.uk/s_usbpin.htm
    Some good help here.
    > case have a 2x5 block connecter rather than individual pins, and of course
    > the wiring for the connector does not match the pinout on my motherboard
    > (an Asus A8V Deluxe). I can easily rearrange the pins in the block to
    > match the motherboard pinout, but unfortunately the case didn't come with
    > docs and I can't find anything online. The wires are all goofy colors, too
    > (yellow, purple, etc., rather that the standard red, white, green and
    > black), so I can't even get any clues from the wire colors.
    > out. <sigh>
  3. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    "Richard Kawamura" <rkawa@concentric.net> wrote in message
    news:Ev2dnSVtb-VYKlnfRVn-sQ@comcast.com...
    > case
    > the
    >> I
    >> I'd
    >> wiring
    >> out. <sigh>
    > Richard
    Greetings, Richard. It's a Chenming CMUI-601AECB-U:
    http://www.newegg.com/Product/Product.asp?Item=N82E16811125436&CMP=OTC-pr1c3watch&ATT=Cases
    I tried googling like a ut but still haven't found any info that tells me
    what each wire is for.
  4. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    > case
    > the
    >> I
    >> I'd
    >> wiring
    >> out. <sigh>
    > Richard
    I tried googling like a but but still haven't found any info that tells me
  5. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    news:N-6dnY7ss7MF1lrfRVn-qQ@comcast.com...
    > > case
    the
    (an
    match
    > > the
    and
    > >> I
    (yellow,
    I
    > >> I'd
    > >> wiring
    find
    > >> out. <sigh>
    > > Richard
    Here's wiring specs for USB.
    http://www.pccables.com/cabtech.htm
    Richard
Homebuilt Cases USB Motherboards Systems Product
