USB 2.0 External Hard Drive Speed
Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
I just got an external hard drive case and put in a hard drive. I was
copying a 60GB backup file to it. It took about an hour to transfer. I
thought it would go much faster. What is the expected speed that I should
expect?
9 answers Last reply
More about external hard drive speed
  1. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Are you sure that you've got it hooked up at USB 2.0 speeds? Cables,
    connector on the computer (as well as the external case) should all be 2.0.
    As well as ensuring your system has the USB 2.0 drivers correctly. Seems to
    me some OS's didn't support 2.0 natively, and you had to add on the right
    drivers.
    According to my math, here's the figures based on the theoretical maximums:
    USB 1.1
    12Mb/s = 1.5MB/s
    6,000MB/1.5MB/s = 4000 seconds
    4000 seconds = 66.67 minutes
    USB 2.0
    480Mb/s = 60MB/s
    6,000MB/60MB/s = 100 seconds
    100 seconds = 1.67 minutes
    Seems you're much closer to the 1.1 speeds than the 2.0 speeds. Here's a
    review of an external USB 2.0 HD, which averaged 26MB/s transfer:
    http://www.tech-mods.net/modules.php?name=Reviews&file=viewreview&op=newreview&id=61
    For 60GB, that would have taken about 4 minutes to copy.
    Clint
    "AFGH" <heiber@nospam.com> wrote in message
    news:nZRze.2426$0w2.996@newssvr19.news.prodigy.com...
    >expect?
  2. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    That is why I am confused. My MB is only about 1 year old with Windows XP
    SP2 and USB 2.0 drivers.
    The properties on the drive say "USB 2.0 Storage Device". The enclosure is
    a Vantec NexStar NST-350U2.
    I am using the cable that came with the drive. Drive is brand new and 7200
    rpm.
    "Clint" <cneufeld@mysocks.shaw.ca> wrote in message
    news:ZZVze.114780$9A2.54503@edtnps89...
    > 2.0. As well as ensuring your system has the USB 2.0 drivers correctly.
    > Seems to me some OS's didn't support 2.0 natively, and you had to add on
    > the right drivers.
    > maximums:
    > USB 1.1
    > 12Mb/s = 1.5MB/s
    > USB 2.0
    > 480Mb/s = 60MB/s
    > Clint
    >>expect?
  3. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    news:sjWze.1826$ER6.316@newssvr17.news.prodigy.com...
    is
    7200
    > rpm.
    > > the right drivers.
    > > maximums:
    > > USB 1.1
    > > 12Mb/s = 1.5MB/s
    > > USB 2.0
    > > 480Mb/s = 60MB/s
    a
    > > Clint
    should
    > >>expect?
    Your math is flawed. Obviously 60GB in 4min would be15GB/min
    60,000,000,000 GB
    26,000,000 / GB/s
    2,307.69230769230769 = s
    60 / m
    38.461538461538462 =minutes
    My USB2(HiSpeed) drive kit says up to 35MB/s. So he's in the ball park to my
    kits specs. Though not the USB2(HiSpeed) spec itself. 480/60 is correct.
    Website for info: usb.org
    YMMV
  4. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    You're right. Move the decimal place on all my calcs... 6,000 MB = 6GB
    (approximately), not 60.
    Clint
    "T Shadow" <knone@zilch.com.invalid> wrote in message
    news:eOWze.3006$yC5.1238@tornado.ohiordc.rr.com...
    >> XP
    > is
    > 7200
    >> rpm.
    >> > on
    >> > the right drivers.
    >> > maximums:
    >> > USB 1.1
    >> > 12Mb/s = 1.5MB/s
    >> > USB 2.0
    >> > 480Mb/s = 60MB/s
    > a
    >> > Clint
    >> >>I
    > should
    >> >>expect?
    > 60,000,000,000 GB
    > 26,000,000 / GB/s
    > 60 / m
    > my
    > YMMV
  5. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Following the link you provided with the review, I downloaded the HD Speed
    utility and ran it. I am getting about 13 - 14 MB/s. So I know it is
    working at 2.0 speeds, but it seems pretty slow for what I should be
    getting. I guess I need to follow up with Vantec.
    news:7cXze.114789$9A2.100088@edtnps89...
    > Clint
    >>> XP
    >> is
    >> 7200
    >>> rpm.
    >>> > correctly.
    >>> > on
    >>> > the right drivers.
    >>> > maximums:
    >>> > USB 1.1
    >>> > 12Mb/s = 1.5MB/s
    >>> > USB 2.0
    >>> > 480Mb/s = 60MB/s
    >>> > Here's
    >> a
    >>> > Clint
    >>> >>I
    >> should
    >>> >>expect?
    >> 60,000,000,000 GB
    >> 26,000,000 / GB/s
    >> 60 / m
    >> my
    >> YMMV
  6. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Hadn't noticed the D/Ls before going to see if I remembered the specs
    correctly. I'll have to check mine when I get on that computer again.
    Biggest file I've moved so far is 13GB. IIRC it took 9-10min so I'm a little
    slow to but the kit specs do say >up to 35MB/s<.
    If your setup is like mine you should check to see if the USB port the drive
    is connected to is sharing an IRQ that's already busy. Putting it on a USB
    port that's on another IRQ might give better performance. I had to move a
    USB1.1 device for that reason.
    news:lFXze.1843$ER6.799@newssvr17.news.prodigy.com...
    > > Clint
    Windows
    > >>> XP
    enclosure
    > >> is
    > >> 7200
    > >>> rpm.
    Cables,
    be
    > >>> > correctly.
    add
    > >>> > on
    > >>> > the right drivers.
    > >>> > maximums:
    > >>> > USB 1.1
    > >>> > 12Mb/s = 1.5MB/s
    > >>> > USB 2.0
    > >>> > 480Mb/s = 60MB/s
    > >>> > Here's
    > >> a
    > >>> > Clint
    was
    transfer.
    > >>> >>I
    > >> should
    > >>> >>expect?
    > >> 60,000,000,000 GB
    > >> 26,000,000 / GB/s
    > >> 60 / m
    to
    > >> my
    correct.
    > >> YMMV
  7. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    In article <lFXze.1843$ER6.799@newssvr17.news.prodigy.com>, AFGH
    says...
    > getting.
    Not really. You have to remember that the maximum pseed for USB 2.0
    assumes nothing else at all is using the PCI bus.
    Conor
    -You wanted an argument? Oh I'm sorry, but this is abuse. You want room
    K5, just along the corridor. Stupid git. (Monty Python)
  8. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    "Conor" <conor.turton@gmail.com> wrote in message
    news:MPG.1d3a6a786fa2ca5e98a2d9@news.individual.net...
    > says...
    >> Speed
    >> getting.
    > Conor
    Mbps = mega bits per second
    MBps = mega bytes per second
    Big difference.
    Ed Cregger
  9. Archived from groups: alt.comp.hardware.pc-homebuilt (More info?)
    Hi,
    USB 2.0 is very slow - almost 70% slower than FIREWIRE (IEEE 1394) connected
    external HDD.
    This is bcs USB uses the CPU to process the signal - IEEE1394 is stand alone
    technology; this is why it's used in/on DV cameras.
    Your USB drive will never work faster than it's current speed. If you want
    fast external HDD, you have to get a case that supports FIREWIRE/IEEE1394.
    L8R
    >expect?
Homebuilt Hardware External Hard Drive Hard Drives USB Systems
